3520A push pull switch
Indianapolis IN
I think I got my VFD working but I also have another issue. Seems the push/pull on/off switch isn't working too well. I have to pull it in and out several times in order for it to turn on. As you might have guessed, that part is no longer available. The switch for the 3520B looks similar but has a different part number. Anyone know if they are interchangeable or where I might find a new Push/pull on/off switch?
Odds are it's either dirt in the mechanical push pull.part or dust in the micro switch that this operates. Just pull the switch and clean and lube everything. If the micro switch is bad it should be easy to find.
As John says, those switches need to be blown out every once in a while. You can find replacements from McMaster-Carr, Grainger, or Amazon. They're not a very sophisticated or durable switch, but replacements are also not costly or hard to install.
Nebraska
Electrical contact cleaner can extend the life of switch contacts when they get dirty. Start/Stop contacts and switches are the first component that usually goes out on a lathe, always worthwhile to have a spare on hand if your income is based on your lathe working.
Traverse City, MI
I got tired of cleaning them and replaced both my switches with light switches from Homer Depot.
