Results 1 to 6 of 6
Thread: Sharpening thread chaser
  1. #1
    Join Date
    May 2010
    The Last Best Place, MT
    Posts
    361
    Default Sharpening thread chaser
    I am considering trying hand thread chasing. I understand that it's not easy and I'm sure it will take a lot of trial and error to learn. I've reviewed all the posts on the subject here on the forum and learned a great deal from the contributors. One thing that puzzles me is how to sharpen the thread chaser. Anybody out there who has and uses one want to clear up the mystery?
    Thanks.
    Dean Center
  2. #2
    Join Date
    Aug 2006
    Apopka, FL
    Posts
    231
    Default
    I'm sure you will get good answers here on the forum, if not, check with Brian Holder or email brian at onegoodturn dot ca. He has a great news letter and is amazing at chasing threads.
    Bill Dalton
    AAW Member # 29leventyHundred
    Forget injuries, never forget kindnesses.
    Confucius
  3. #3
    Join Date
    Sep 2010
    Stow,Ohio
    Posts
    148
    Default
    I believe you use a honing stone across the side of the tool. Never touching the front of the teeth. Just what I've heard.
  4. #4
    Join Date
    Aug 2011
    South Florida
    Posts
    Default Sharpening Thread Chaser
    I have just learned to chase threads. It does take a lot of trial and error. The cutting surface is the top surface so using a medium or fine honing stone often on the top surface does a nice job for me. Make sure not to touch the teeth. A threaded box top or plug makes such a difference in a piece.
  5. #5
    Join Date
    Apr 2004
    Cookeville TN USA
    Posts
    4,988
    Default
    I've built my own thread chasers as well as purchased a few. Honing the top is what you do. Cutting the teeth with the V file takes lots of patience, a good magnifier and a thread pitch gauge. So unless you want to build your own or picked up a used set that is in really bad condition I would never touch the teeth.
    I had an article on how to build them in Woodturning design about 3 or 4 issues ago (can't remember and don't have time to look this morning but if you need to know I'll look later tonight)
  6. #6
    Default
    Cutting threads in wood is relatively easy. Run your lathe slowly. Take your time. Check fit often.
    I make my own thread chaser by starting with a good piece of tool steel, and cutting my own threads in it (you could use a bolt, but the steel isn't always that great). Once I have threaded about 1", I grind the top flat half way through the diameter, and then hone it with a small diamond lap to a mirror finish.
    I have a video on YouTube if you want to see if in action. Shouldn't take you more than 30 minutes to make, and perhaps 10 minutes to learn to use if you watch the video.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
