AAW Forums
Go Back   AAW Forums > Main Category > Main Forum
Register Help, Rules, & FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 02-18-2008, 09:36 AM
Dustpan Dustpan is offline
Default bowl steady
I am needing plans for a bowl steady made of bb plywood. I have a PM3520b that has a 10 in. swing or 20 in. blank. Any help out there? Thanky, Max
  #2
Old 02-18-2008, 12:20 PM
GeorgeH's Avatar
GeorgeH GeorgeH is offline
Default
http://www.davidreedsmith.com/Articl.../magsteady.htm
http://www.easttexaswoodturners.org/Steadyrest-Mini.htm
http://www.turnwood.net/projects/SteadyRest.pdf
__________________
As you advance into old age, the value of your opinions progressively diminishes. Eventually they have no influence on either the present or the future; you're relegated to a segment of humanity that is tolerated but not taken seriously. What "is" and what "will be", as you might interpret it, no longer has meaning. All you have left is the opportunity to reflect on what once was, while arguing with your fellow seniors who remember it differently.
George
Gold Country Woodturners
  #3
Old 02-18-2008, 02:48 PM
John King's Avatar
John King John King is offline
Default
Checkout following links and attached pdf file. - John
http://www.newwoodworker.com/stdyrstpln.html
http://www.woodcentral.com/articles/...cles_128.shtml
Last edited by Steve Worcester : 02-18-2008 at 04:23 PM. Reason: Removeal of copywritten material
  #4
Old 02-18-2008, 04:03 PM
Bill Boehme's Avatar
Bill Boehme Bill Boehme is online now
Location: North Central Texas -- Dallas / Fort Worth Metroplex
Default I like most all of them ...
The one by Tom Crosby of the Woodturners of East Texas is very nice and could easily scaled up in size for a larger lathe. In fact most of these are very much alike except for the first one which a clever idea for a spindle steady. The detailed step by step procedure in the plans by Ray Lanham is useful even if building a different design which is fortunate since the link given in the instructions no longer works. The plans offered by Tom Hintz are very similar to the others if they are the same as the free plans that he had several years ago. A couple bucks isn't too much to pay for already printed plans. I like the lock down mechanism on the plans by Dominic Greco. Finally, the use of aluminum T-track in the Fine Woodworking article is a clever idea that I would very seriously consider because of its sturdiness and ease of adjustment.
Bill
  #5
Old 02-18-2008, 04:58 PM
John King's Avatar
Default
Max - A pdf file that was attached to my original post was removed because it was a copyright article. You can find the article in Fine Woodworking Magazine, Issue No. 143, Page 14. The article is titled Shopmade Steady Rest.
My experience is that most public libraries have back issues of Fine Woodworking Magazine; therefore, no need to purchase a back issue to get the steady rest article.
Good luck. - John
  #6
Old 02-18-2008, 08:52 PM
Default
Max, I have back issues for about the last 15 years so if you need it, I will loan it to you for a nominal fee (free).
  #7
Old 02-20-2008, 09:31 AM
Bruce McElhaney Bruce McElhaney is offline
Default Bowl Steady plans
I built one using this fine plan by Dominic Greco. I've used it on bowls vases and peppermills. It works great, however I rarely use it these days except for tall vases as my technique has improved and feel it's overkill for me. But If you tend to launch a lot of bowls, then you need one.
I would just add if you do use a bowl steady make sure the bowl is completely round, and keep the wheel pressure light as they can create marks on your finish. Some folks use masking tape on the finished wood where the wheels run to prevent that problem.
  #8
Old 02-20-2008, 02:53 PM
MichaelMouse's Avatar
MichaelMouse MichaelMouse is offline
Default
I just hinted at how nice it would be to see a Oneway steady with appropriate block under the tree. New lathe, new block. Spindle steady fits the same base. That was fathers' day.
__________________
Stand clear, rest near, and cut the wood as it wishes to be cut.
  #9
Old 02-21-2008, 10:50 PM
odie's Avatar
odie odie is offline
Default
Quote:
MM......
I have the Oneway Bowl Steady......and find it to be a well made attachment. It costs a hundred bucks, but I think it's well worth it. I did do some modifications to mine that improved the performance. It absolutely does soften the vibrations of the bowl while cutting the interior.....great! I give it my recommendation........
otis of cologne.
__________________
You may see pics of my shop and turnings by clicking on the following URL:
http://www.picturetrail.com/taipan22alpha
Yeee..haaaaa! "Odie's Crazy Ideas" now has a folder online.
Constitutionalist, American Patriot.
  #10
Old 02-23-2008, 07:53 AM
Donna Banfield's Avatar
Donna Banfield Donna Banfield is offline
Default Modifications?
Odie, you mention some modifications to your Oneway Bowl Steady, that made performance better. Could you share your modifications with us, and what improvement they made?
I have the Oneway Bowl Steady, and have already gone through a set of wheels trying to find the fine line between not enough support and too much (i.e., leaving long rubber skid marks on the bowl exterior).
__________________
Woodturning...it's not just a past time, it's all the time...
www.livealifelessordinary.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This is my copyright text
