AAW Forums
Go Back   AAW Forums > Main Category > How-To's, Tips, and Techniques
Register Help, Rules, & FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 12-21-2008, 08:44 PM
Gary Slater Gary Slater is offline
Default Build an Air Filtration System
I have a med-lg squirrel cage blower and want to build an air filtraton box. Any good plans out there? I have found a couple on-line but was just wondering if anyone out there has actually built their own. Thanks!
  #2
Old 12-22-2008, 10:11 AM
Steve Worcester's Avatar
Steve Worcester Steve Worcester is offline
Default
Early on I built one. Not that tough. Basic box, a good washable filter,sealant,the blower and a switch. You may want to look at some Jet, etc., designs and design your particular system to take their pre-made 1st/2nd stage filters.
Post the links for the others you have seen and lets check those out.
How many CFM is the blower you have?
__________________
Steve Worcester
AAW Forum Administrator
www.turningwood.com
Become a Turningwood fan on Facebook!
  #3
Old 12-22-2008, 11:27 AM
Turnedoutright's Avatar
Turnedoutright Turnedoutright is offline
Default Unimpressive dust filter
The unit show in
http://www.turnedoutright.com/2008/0...op-made-tools/
was made as an experiment after reading a lot on the subject.
I planned to build an advanced version of this after finding out if it worked.
I know this approach is not better than a professional unit but I was astonished how well this approach worked.
I replace the fine air conditioning filter every month and its filthy. I don't know what I could do to improve it other than put it in a pretty box or add one more at the other end of the shop.
I figure that if I'm collecting dust at this rate it must be better than nothing.
BTW this is in addition to my normal vacuum system.
I also like the fact that it is very quiet.
__________________
Make it a good day!
Turnedoutright
  #4
Old 12-22-2008, 06:15 PM
Default
Here are two web sites where I found plans for air filtration:
http://books.google.com/books?id=fYE...esult#PPA65,M1
http://www.rockslide.org/Images/air_filter.pdf
I had plans for a similar system from one of the woodworking journals a couple of years ago but have misplaced the article and can not remember which journal it appeared in.
  #5
Old 12-23-2008, 04:41 PM
Malcolm Smith Malcolm Smith is offline
Default
I heve a regular filtered dust collection system. I don't remember who makes it. The important thing is the filters themselves. There are aftermarket filters which remove much finer dust. In addition I wear a pressurized mask system while turning. If I'm sanding, I wear the mask and also run the regular collection system. I have both as they really don't do the same thing.
Malcolm Smith.
  #6
Old 12-24-2008, 05:17 PM
rsser's Avatar
rsser rsser is online now
Default
Yes, we should do all we can, but I do worry about whether it's enough. Seems current systems will let through a proportion of stuff at the damaging 4 micron and below size.
__________________
Cheers, Ern
  #7
Old 12-25-2008, 01:14 PM
Default Home Built Air Filtration Plans
I finally found the plans I was looking for. It was in part of a supplement to Shop Notes about two years ago. The article is titled "Shop Air Filter" and the supplement was "The Complete Small Shop". Due to copyright, I can not post the article. However, I can not find it online either. I might try posting some of it if our moderator can think of a way to do it legally.
The plan calls for about 3 bd ft of hardwood and just over half sheet of 3/4 plywood; a squirrel cage blower (you can pick up on ebay or at your local HVAC dealer-they get them used out of old furnaces etc.); and three pleted air filters. My guess is it would approach or exceed 1000 CFM with the right size blower. That will filter a 20' ft garage about a dozen times an hour!
Now, I found Jet's AFS-1000B at the local Menards on sale for only $160. So do I build my own or take the easy way out?
  #8
Old 12-25-2008, 03:45 PM
Bob Edwards's Avatar
Bob Edwards Bob Edwards is offline
Default
My "filtration system" doesn't employ a filter at all. I find a small fan blowing from the tail stock end and slightly away from me is the most effective dust control I have. This along with a dust mask from www.totobobo.com is all I have. I will add that in my shop I installed a window to the outside just three feet from the headstock end of the lathe. I also live in a climate where I don't have to heat the shop.
__________________
Bob Edwards
San Antonio, TX
  #9
Old 12-28-2008, 09:29 AM
Vinces WoodNWonders Vinces WoodNWonders is offline
Default Dust Mask and Collection Systems
Like Malcolm I have a regular filtered dust collection system for the shop. I am installing a toggle switch just behind the lathe so I can better turn it on and off as needed. I have a floor sweep and a hose line dedicated to the lathe.
However more importantly I have begun using a very comfortable Totobobo face mask at all time when in the shop. I put it on when I put on my eye protection and it is so easy to wear and comfortable I forget I am wearing the mask partially because it is so light weight. It is absolutely incredible how much dust particles these filters will pick up. I had no idea!!! One thing for sure is that I no longer spend 2 days blowing dust out of my nose after working in the shop. If you need any info concerning this mask feel free to contact me at 1-877-284-8969 or www.VincesWoodNWonders.com.
Vince
__________________
  #10
Old 12-29-2008, 11:44 AM
michael h michael h is offline
Default
I made a hanging dust collector with plans from the Fine Woodworking book
'Workshop (or woodshop) Dust Collecting' . It came out a few years ago and I believe was updated. Its a simple project, and quite a bit less expensive then a commercial unit,especially if you have plywood pieces around. I buy my filters through Grainger by the box and save a bit that way as well.
Of course its important to protect your lungs at point of dust generation , the boxes get the stuff that would otherwise float around your shop before settling or breathed in.
good luck,
Michael Hampel
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This is my copyright text
