| Register | Help, Rules, & FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1
Anyone have a chance to check out this lathe? I know that many turners do not necessarily like the Grizzly lathes, but this one is interesting due to capacity and price.
One thing that is interesting is that it has single phase output. Almost all of the VFDs are three phase out. If I remember correctly, the drive is more complicated and I dont know that it is as reliable - I heard of manufacturers getting away from this type of drive. My first real consideration is the Jet 1642. However, this one is interesting.
__________________
Rich To the world, you might be one person, but to one person, you might be the world. |
#2
Rich I believe it says the motor is 3 phase which means the output of the VFD is 3 phase. I believe they are trying to tell you it runs off of 220 volt single phase. They are calling it a single phase VFD but I'll bet that it's simply single phase in 3 phase out just like all the other lathes.
I don't know where you heard that other lathes were dropping these drives. If anything more manufacturers are picking them up. The New Delta mini for example uses a VFD. As far as the lathe goes I've been trying to watch peoples responses on the Grizzly lathes and don't get huge amount of really bad press but not a lot of great press. It's a good price and probably worth the money. Grizzly products have improved since I owned several but I don't think they are at the top of the game yet. |
#3
the Griz works the same way, has single phase input to the VFD and the VFD converts it to 3 phase for the motor.
While not a fan of Grizzly, it looks a lot like the Powermatic.
__________________
Steve Worcester AAW Forum Administrator www.turningwood.com Become a Turningwood fan on Facebook! |
#4
Hello, I am new to this forum, and have owned a lathe for about 7 years, which recently broke a gear shaft[craftsman 351.217170] and cannot get replacement parts to repair it. I ordered the grizzly G0698 18x47 lathe on new years day. I did a lot of research, and it is the same as the Laguna 1847 and the Craftex 128 buy busy bee, only made to Grizzly's American specs. After over 3 years of manufacture they should have all the bugs worked out, and as far as I know it is manufactured in the same plant as the Jet and Powermatic's are, and has the features that are state of the art.
While I would like to have purchased a 3520b powermatic which is considered a "cadillac" lathe, this one is probably a pretty good 'Buick," so I believe that I can do well with it and Grizzly has an excellent reputation for customer service should any service be needed in the future, and the price was great at $1295.00 plus shipping. It is scheduled to be shipped around Jan. 25th and when I get it set up [I have to change a circuit in my shop to 220v] I will give my initial impressions, and some ongoing reviews as I am able to use it to do new projects along. |
#5
Quote:
You are correct that more and more lathes are being offered with VFD, but with 3 phase output. I try to be careful and not read more into an advertisement than is being said. I have been burned one too many times making the add say what I want it to say (also I have read adds wrong before) - I have learned to take it literal and ask questions - make the salesperson earn their money. I would hope that they are trying to stress that the input power required is 220V single phase. However, their ad is not clear, if that is what they are trying to say. I just emailed Grizzly customer service to get this question cleared up. You are correct, the catalog and the add on the website both say that it is a 3 phase motor. I read it incorrectly last night before I made the original post. Sorry for the confusion. I think I know what the response will be.
__________________
Rich To the world, you might be one person, but to one person, you might be the world. Last edited by Rich Aldrich : 01-15-2010 at 08:03 PM. Reason: added last paragraph. |
#6
Quote:
I look forward to your appraisal of this lathe. Given my budget, I can buy a Jet 1642 and that is it. If I could buy the Grizzly, I could afford turning tools, sharpening guide, and a new slow speed grinder right away. I could probably even afford a chuck.
__________________
#7
Hi Rich, I believe this lathe is a large cut above what a lot of the lathes in grizzly's line up have been in the past. A number of owners of the laguna and the other versions from busy bee [canada] and hare & forbes [austrailia] have been very pleased with the smooth and quiet performance and the power of the lathe, as well as the variable frequency drive which allows for a lot of torque at low rpm's.
Although this lathe is newly carried by grizzly, the machine has a track record of over 3 years world-wide and from what I understand the machining is first quality. Probably for the money, you won't find more lathe, more features, or more value. Grizzly is supposed to have first rate customer service, and should stand behind this 100%. I did a lot of thinking and comparing and research before I took the leap, but I feel pretty good about it, and at $1295.00 I don't think I have made a decision that I am likely to regret. I am a stickler for precision and quality, so it won't take me long to get a sense of quality and performance. - good luck! |
#8
John,
You are correct, the Grizzly 0698 does put out 3 phase. I heard back from Grizzly.
__________________
#9
what about the shop fox lathe 16x43= w1758 2 differnt guys have them new on ebay shipped for 600.00 or less! anyboy know about these? its a great buy. thanks; daniel
#10
Quote:
- Power switch has a propensity to fail - Alignment problems between headstock and tail stock - You will need to add weight to it or fix it to your shop floor to turn rough cut timber larger than 5" in diameter. - Digital Output has a propensity to fail - If you decide to rotate the headstock to turn "outboard" you'll likely decide to use the articulating banjo - this will vibrate. - The "spring screw" handles on the banjo will likely strip out. - The low speed on the lathe (600 RPM) is fairly fast for roughing bowls larger than 8" diameter. Conversely, the 2400 RPM upper limit is a little slow for finishing spindles (I'd prefer 3200). I have the grizzly model and these are the things I have experienced with this lathe. For what its worth - this has been a great lathe for me and for what I do, however my next lathe will be a lathe that addresses these problems, or at least the alignment, spring screws, and low/high speed problems. I'm going to look for an EVS model personally. |
| Thread Tools | |
| Display Modes | |
