2nd Tool Handle Done
Middle TN
followingghost.com
Got in the shop this morning and tries to work but just wasn't feeling it, a bit under the weather. I turned a couple of calls then started on a tool handle but gave up. Felt a little better later so went back out to try and get something done after a miserable, stress filled week I needed some shop time.
I decided to finish my handle so I can glue it together and let it start earning its' keep. Went with the same glue up pattern but changed the grip style a lot. Thicker, shorter with a double taper where I like to grip the handle. Cherry and poplar just under 15" finished with 3 coats of Johnson Paste Wax thinned with mineral spirits applied with 1000 grit paper and buffed.
