• It's time to cast your vote in the August 2025 Turning Challenge. (click here for details)
  • Congratulations to Ted Pelfrey for "Cherry Burl" being selected as Turning of the Week for September 1, 2025 (click here for details)
6 jaw chuck.
I have just finished repairing this 6 jaw chuck for one of our club members. It was totally frozen. I had to drive the threaded part off. Had to put it on the lathe and use a boring cutter to clean up the inside. I was able to clean up the male portion with sandpaper after mounting it on the lathe. Had to turn off a hair of the spiral gear to get rid of damage and poor surface. Then used a diamond bit in my dremel to round over the teeth on that gear.
. None if the jaws would slide so i Had to hand file all the slide rails on the chuck body and then sand the sides of each jaw until I got tgem all to slide. Got it all together and working. It's missing the big external snap ring. I used wire to fill that gap temporarily until I can get snap ring.
Does anyone know who made this thing. It's a tommy bar chuck.
Not applicable to wood turning perhaps, but some may find this interesting.
It’s perhaps an interesting point that I watched a video from the 1980’s, where a woodturner was using a standard 3 Jaw Chuck. Special Jaws suitable to the task had been made for it. Some say that the reason we use 4 Jaw Chucks is because it’s easier to manufacture the Top, or Accessory Jaws. This may have been true in the early days but seeing Axminster cut their Accessory on a CNC Mill rather than say a Bandsaw negates that premise now.
This begs the question, how would a 3 Jaw Wood Turning Chuck perform? Changing Chuck Jaws would be quicker for sure! 🤣
Beyond the perfect circle position, each jaw is like a line segment approximating the curve of the larger diameter circle. More line segments better approximate a curve, so more jaws should provide a more perfect circle-like grip over a wider range of circle diameters, so it might not create marks at a diameter at which four jaws would.
Odie posted a picture of a 6 jaw chuck a few years ago on this forum. I have seen them in catalogs before but don't recall whose it was
