Accelerating cherry wood's color change
Durham, N.C.
I'm looking for information on using UV light to obtain the natural color change in fresh, pale cherry burl. Would the lights for UV curing finishes be strong enough to efficiently eliminate the pale look? Maybe 20-30 minutes vs hours. The idea is to turn the burl pens to the pre-finish stage, change the color, and then apply the finish. No stains, dyes, or water borne chemicals involved.
Have you tried baking soda in water? It’s about as safe as it gets and since water will raise the grain, a plus for sanding.
Like Richard said, I would find a south facing window and sit it there. In mid summer, if you leave a business card on a piece of cherry for an hour and come back and pick it up, it will have sun burned.
Perhaps some useful reading:
Some recommend using a UV lamp. I have a powerful UV bulbs made for sterilizing thing I'd try first. (caution, can damage eyes)
Potassium dichromate is sometimes used to darken the tannins in wood.
One person recommended using lye in water.
I think I'd do tests on scrap before committing to a method.
There is a formula out there to age cherry. Been top many years since I did it. I'm sure you could find it doing a search
Put it in the outdoor sunlight for a few hours. The cherry seems to only slightly change color, but when you hit it with oil or polyurethane it turns dark. Try this on a piece of board to see if you like the result.
I’ve don’t this before. Works great and is easy. Test on a scrap and see what you think. FWIW, lye and baking soda are both bases. Lye is just much stronger (and more precautions need to be taken with its use).
Fumed cherry is nice as well, but I’ve seen it go very dark from this, so be sure to run a test if you go that route as well.
Thanks to all of you. Having built and restored furniture for over 50 years, I can attest that all of your recommendations work. Limiting factors were many. Grandson had ONE piece of dry cherry burl just BARELY large enough to make a pen for his girlfriends father. It was important to be successful because the wood belongs to her father and was supposed to be a Christmas present. Thus no testing on scrap or waiting for the sun. The pen is finished, but would still like to hear from anyone who has1766705156270.png experience with a UV light system.
