Advice needed, tool or technique
Van Alstyne, TX
Seems Midnight + is a good time to seek help!
Guys n gals,
In the pic below,
What tool and or technique would you advise?
While turning the inside;
I was quite afraid of catches. ( last step)
And I observed that with my smaller tools, the bevel, rather than the cutting edge would contact the surface.
Ok, perhaps not unexpected. I can imagine that cutting edge to center of the work certainly plays a role.
I do have a micro sorby set.
Round nose scraper, tiny gouge.
1/4” skew.
These I sell. So of course a catch is not allowed.
I appreciate any teaching you can offer!
Best regards,
George of the Lathe Jungle.
PS the inside was initially bored with a step drill bit.
I was getting close… chickened out!
Howdy George, I love my Sorby Micro tools but depending on how far you need to go into the form, they will not be sturdy enough to give good results. I have a 1/2" wide scraper that I ground to a round nose negative rake (Double Bevel Scraper) that is much sturdier. The round shape is easy to control and blend cuts inside boxes and such. The thing is that scraper is still 1/4" thick stock and so the underside of the left side will hit easily on the inside of a small diameter like you have there. The solution is to grind away the left underside so it won't hit the project side wall and ruin your cut. While you are at it, go ahead and continue that negative rake down that left side of the tool too. Gentle cuts with a fresh bur on the Negative Rake will help tremendously.
A round nose or square nose with a radius carbide tool could work, but with your inside diameter so small, you would need to heavily modify it by removing lots of supporting metal under the cutter. If you do that, go on Amazon and buy the cheapest round nose carbide tool you can find before you commit to grinding things away that you can't put back. Easy Wood Tools makes a negative rake cutter for their tools but there are other options out there if you look.
The last suggestion is a reminder not to stick sandpaper in there along with a finger to hold it! Broken fingers are no fun. Use a dowell with a slit cut in it to hold the sandpaper or maybe hook and loop would work too. And no... woodworking is not how I know about broken fingers.... soccer ball hit was the worst.
Best of luck!
I would make or buy a Oland type hollowing tool, cheap and highly effective. The tips can be made out any HSS steel ie old or broken tap, drill bits, reamers, or buy HSS in short lengths either square or round, some where around 6mm, 5mm etc
Oland tools
Gey the Hunter Viceroy cupped carbide tool. Ive been hollowing my boxes for 20 years using a 1/2" spindke gouges cutting front center out. I have been playing a lot with the Hunter Viceroy. Fantastic tool. Almost fool proof to use. Leaves a pretty good finish if you make light passes at the end. I have 2 videos that show this tool. One on turning boxes and one on the Viceroy itself.
Well I cant figure out how to attach those links. Go to YouTube and type in johnlucaswoodturner/boxes. The try johnlucaswoidturner/viceroy
Endgrain, so center to rim cut. I would start with 3/8” shaft spindle gouge. Then there are several options, I think my 1/2” shaft 8.9mm flat top carbide hollower would fit, probably try it next. Also have the same cutter on a 3/8” shaft. Then a 1/2” neg rake scraper for final smoothing. I also have some smaller hss scrapers that might be useful.
A 6mm cupped carbide cutter (like a Hunter) would work as well. I only have a larger cupped carbide, not sure it would fit.
It’s good to have several options available to see what works best. Different woods, and even a different piece of the same wood can behave a bit differently.
good ideas here :) some a bit pricey lol!
I do have Metal lathe tooling as mentioned above, so I will dig into that tool box drawer first.
Then I like the idea of a cheaper round carbide bit tool, with bevel and possibly bottom side ground for more clearance.
Thanks very much!
If you want cheaper, grind a small scraper into a box scraper and scrape on the edge of the tool. Rotate it a little bit CCW and keep the handle higher than the working end to limit catches.
Looks to be deep enough that it might require hollow form tools. I make a lot of boxes, and the ones that are more than 4 or 5 inches deep, they almost take hollow form tools. Most can be rotated for a shear scrape so you get a cleaner bottom. I use a lot of NRSs/negative rake scrapers in my boxes just because they cut so cleanly, but they are not tools for removing a lot of stock. The Hunter carbide tools should work fine for nice clean cuts.
I'll add my endorsement for the Hunter tools. I'm not sure of the opening size as it gets down in there but the Badger would be a great tool provided it fits all the way down for you (5/8" bar tapered down to a 3/8" cutter). If not, the straight ornament tool would work but you might be hanging out a ways off of the tool rest for it's 3/8" bar. Hunter tools aren't cheap, but I have yet to talk with anyone that has regretted buying one.
Thanks very much!
Remember carbide tools if you wish to sharpen you will need a diamond wheel set up and the dust is very toxic.
Why the Viceroy rather than the Badger?
The Easy Wood Tools full size carbide scrapers may have a longer reach than those Hunter tools if he needs to get down that far. What would be really useful is an EWT Pro square cutter swept inboard for hollowing and squaring up inside corners.
Currently a fan-boy or Easy wood tools. Have several examples of mid and up in Ci3 to Ci0 inserts.
None of those will fit inside. :)
The Call was originally bored with a std. drill bit to 1/2", followed by two different step bits. Wanting to get rid of the steps as deep in length as possible while following the outside taper.
some few steps will always be left.
Unless I (make a mess) with the ex's inexpensive HF rotary Carver. LOL. ( I should get a few bits for it anyway.)
after reading these suggestions, I bit the bullet and ordered the EWT Ci5 micro finisher, along with a NR insert. Overall it will be very usefull!
Due to a very very fortunate market place find, I have several nice turning tools (Thompson) though not insert types , they do cover a range. just enough of them to maybe sell a few sorbys.
Sheesh,the total cost was under the price of just one Thompson tool :)
Thanks for the replies, this is a good conversation!
I do have an assortment of HSS and "less-than" steel tools.
Kind of a nasty job to perform, lol.
Made worse by the fact that what I have for hogging metal is ready for the trash can!
Thank you Hughie. Yes, very true that carbide dust is bad. To be clear, my idea is to only grind away metal from the supporting bar the carbide bit is mounted on.
Curt I have a couple of carbide tipped gouges very similar to the New Zealand Woodcut.
Oh my! I don't remember seeing those before. I am wondering if you have the edges chip on those notorious Australian hardwoods?
No carbide is fine, I made couple out of Tantung and the wings proved to brittle for a conventenial grind had to increase the angle to gain thickness. The carbide will last up to 10 times longer on most hardwoods from here, but the reality is not much defeats local hardwoods
