Almost a catastrophe!
Gardner, MA
Went down into the shop to package up a cigar holder and get it out to the mail. Decided I should throw on another coat of wax before boxing.
I wasn't wearing proper clothing. I was tired and sore from shoveling! I wasn't paying attention as I was still looking for a proper size box! I was in a rush!
These chuck jaws are super sharp where the screws go in. Before I could even blink they grabbed my loose sweat shirt sleeve and sucked me into the machine!! Thank god I was only spinning at 4 or 5 hundred RPM. At least I followed one rule of safety and had the on/off box right at my finger tips.
Tore the shirt all to hell! Twisted my arm around pretty good but no serious damage.
Moral to the story:
Be careful out there! Always follow the safety rules!
Chuck jaws will no longer be used. I ordered replacements.
Glad you escaped without serious damage, Phil! I have learned to NEVER turn when I am tired, stressed, frustrated or some other negative feeling. Better to just leave it for another day. I too got to learn a hard lesson at the lathe recently without too much damage.
These were cheap jaws I got on Ebay or Amazon. Should have kept my money!
Sucks that they would work with a 5/8 hole. Can't find any others to fit my Nova chucks.
Might try to grind them smooth. If not they will go in the recycle bin!
Thank you for posting this - a good reminder.
So glad it wasn't a a serious injury. I think about that hazard when I go into the shop with long sleeves! I'm thankful for good heat for turning on cold days.
Looking at those jaws... Do you usually leave them on that chuck or change them often? If left on the chuck, could wooden plugs be turned to fit the holes to the screws to eliminate the sharp corners? Otherwise, I like the idea of modifying the jaws if they are otherwise useful, perhaps grinding with a dremel. I've also modified/reshaped steel chuck jaws by turning them down with a 1/2" scraper (Thompson steel, sharpened a bit like a metal-cutting tool bit.) It wasn't fast nor fun but worked.
Another thing some do is wrap tape around the sharp parts of jaws after mounting. I like the Scotch 2060, sticks well to almost anything. I also say someone stretch short section of rubber inner tube around jaws - allows for loosening and tightening the jaws - something like a piece of inner tube from a bicycle tire might work.
I've never seen that type of jaws, look useful for holding small diameter tenons or small recesses. Have you tried the Nova pin jaws? - I have several sets of small jaws in several diameters that might do - 17mm, 25mm, 31mm, etc.
FWIW, I like the new Nova dome jaw set (6091) - has a small dovetail for a recess and will hold a very small diameter tenon, dowel, etc. These might not fit that project but the access they provide on the headstock end has been helpful for several projects.
View attachment 82379 View attachment 82381
Haven't heard or seen them. Off to the internet to find some!
Every jaw set I have has had the outside corners rounded off to at least lessen the damage of knuckles, tools, or whatever coming into contact with those sharp corners. I’ve bruised some fingers and knuckles , that would have been sliced open if not rounded off. Glad you survived without injury.
Ist pic same type of jaws, 2nd pic large #3 tower jaws
I'm pretty sure my Nova pin jaws handle 5/8", but they could still eat a sweatshirt. Maybe a collet chuck would be a good solution.
I took a recent 1-day intensive "slicing" wood class with Mark Sillay down in Tucker, Georgia (it really advanced my spindle-gouge work too!). He rounds off his sharp jaw corners too because he rests the flesh of his palm on the comfort rest, sometimes real close to the spinning jaws.
I found a set of those exact jaws in my collection and I think I am just going to throw them away.
I know I could spend a lot of time grinding the corners off, but I would never not be nervous around them.
Think I'll get a set of the Nova dome jaws.
View attachment 82330View attachment 82331
Moral to the story:
I'm glad you're safe.
I use blue tape - painter's tape.. its cheap.. and I wrap it around chuck body and/or jaws as a visual colored reminder where not to go.. and often I also make a little "flag" of about 1/4" length from the leftover end as another "warning" when fingers get too close - that little flag warns me I'm about to jam a knuckle or something into a jaw... I have a set of those jaws on my Barracuda chuck set - don't use it any more since it is 1" direct thread so it just sits with cole jaws attached (plus 1-1/4 adapter) for the few times I need cole jaws... but I still use the tape trick on many projects where I worry about getting to close to a "corner" or something that sticks out or interrupted cut.. many times has saved me from skinned knuckles..
I found that after Teknatool aka Nova moved to China I found that I had to do some fettling on the new Chinese made products. As you say razour sharp edges aint there for happy endings, glad you survived.
For cooler weather, I had my wife cut off some old long sleeve shirts between the wrist and elbow. Started working summer 1964 for a heavy manufacturer who had all kinds of machinery. Know of some bad injuries in the plant. One machine was a 12,000 ton press brake...do the math. I only operated the power equipment in the model shop under the supervision of some great guys.
I bought some very light-weight disposable paper jackets I saw at the dentist office. Some like them to keep chips out of uncomfortable places. The paper will rip if snagged.
Most want the sleeves cut off half way.
This friend from Italy is starting on her first project after the starter skew lesson.
Very pleased that you survived that incident and able to tell us the story Phil.
I've never seen anything as dangerous as those jaws from a reputable chuck maker. If we are are buying stuff from the byways we have to exercise more caution and thought., but we woodturners will experiment and improvise!
I acquired the following little three-jaw chuck for a particular use. It was designed for small parts metal machining where the operator would be well away from the action when spinning, so I had to do some heavy duty fettling to make it safe for woodturning. I knew from using metal turning chucks on wood lathes back before the modern woodturning chucks became available that they are a disaster wating to happen. Here is the little three-jaw chuck as received and after fettling...
