Always learn from another turner
After you have watched a video several times, mute the sound and watch the turners movements (body and tools). Do this until you can fully associate what they say with what they do. At the lathe, this makes it much easier to execute the cut you want to make. Maybe pick one turner to study thoroughly before moving to the next one.
Good luck
OK, there is youtube but stick to well known names, many run their own channels, Stuart Batty, Jimmy Clews,Richard Raffin etc
I can personally recommend : Turnawoodbowl.com (Kent Weakley) , RIchard Raffan, Tomislav Tomasic, Wyoming Woodturner, Mike Peace, and Dean's Woodworking to name the ones I learned from (and still do) If you want links to their channels on Youtube, drop me a note and I'll PM them to you. Kent Weakley would likely be the place to get started, he has a lot of info on sharpening, and techniques (No need to buy any of his courses, which he seems to regularly plug.)
All of those named turners are good turners and teachers. But, if you can't get to a hands on workshop with any of them where they can observe your technique and correct you then their videos are the next best option.
They all have something different to offer and no single presenter will teach you everything you need to know, so be open to them all to begin with.
Watch.... go and try... go back and watch again... try again... etc, etc.
Start with videos on tool types and uses, like these videos by Richard Raffan
View: https://www.youtube.com/watch?v=bA_-sIVkxLo
View: https://www.youtube.com/watch?v=qAz1FfAtqmE
On sharpening, some of the most experienced turners don't use jigs, but I encourage you to use the Oneway jigs that are on the way to you courtesy of Bill, at least to begin with.
Turning wood completely away to gain proficiency, rather than to get a product, is a good way to begin. After 55yrs of turning I occasionally still do that to begin a woodturning session in an attempt to maintain my proficiency as my overall dexterity and mental acuity declines... 😅
Agreed I still do that often enough, usually with a piece of wood that was intended to be a project but turned out to have defects making it unusable for that project - Rather than unchuck it and set it aside for later use for something smaller, I often just keep turning it into shavings for technique practice (especially with tools I wasn't planning to use on that project, but applicable to the grain orientation, and infrequently used) and lots of firewood scraps I can grab from wherever when I just want some practice.
I do that with students. We start with spindles and by the time they turn a couple of 2x2s down to almost nothing they've got the skew, spindle gouge, and roughing gouge mostly figured out. I'm always there watching, suggesting. No catches allowed!
I often do something similar, but with a variation - not necessarily turning the practice piece down to splinters..
When turning a project, as I get half way to the final shape I'll start practicing "final" finishing cuts early. I'll try a different tool, one with a different grind, various lathe and tool movement speeds, different tool presentation, etc, and make a final practice cut. I do this multiple times. For example, if I intend a vase to have a 2" neck I might start making practice cuts when the neck was closer to 3" diameter - gives me 1/2" of wood for practice.
By the time I reach the final shape, thickness, etc, I've had a lot of practice and discovered which tool and method DOESN'T work a well and what does works for THAT shape and that piece of wood. My final "final" cut is more likely to be as perfect as I can get it and require minimal sanding.
This does take more time, but hey, I'm turning for the joy of it instead of competing in a speed contest. The worst thing for me is to quickly hog out the wood to size then find out too late the tool I picked for the finishing cut wasn't the best. (This "sneak up on it" method also avoids the surprise problem of tearout on the final cut on the outside of a bowl or such - I can figure out how to deal with the tearout on that wood and that shape earlier instead of later.)
One example: when turning long straight sections on thin spindles using certain osage orange blanks I discovered a skew with a small included angle caused some fibers on to pry out of the wood, sort of like long, linear tearout. However, if I used a skew with a larger included angle, a different skew angle, a certain spindle roughing gouge, or even a different cutting speed I got a much cleaner cut for THAT wood. It was good to find that out during practice long before making the finishing cut!
The best thing: with this kind of practice I eventually learned which tools were more likely to work best for certain situations. It amazed me how much better some tools in my kit worked better and now feel more "right" than others for the same cut. I still continue to make multiple finishing cuts but I think this has improved my turning overall.
I started doing this years ago and show it to others. I'm a believer.
I think it was Sir John Lucas that told me in the deep past he sometimes did the same thing. Another friend told me he does that often, especially on new shapes. This might not be of interest to those who turn similar bowl shapes over and over. Or those who are automatically good at everything they attemp!
But, if you can't get to a hands on workshop with any of them where they can observe your technique and correct you then their videos...
From my own experience, this is massively important. It's so easy to correct something early than after it becomes habit.
With any student, I am there to watch and correct every move, for example, when learning spindle turning:
basic anchor/bevel/cut,​
skew presentation,​
cutting point on the skew edge,​
consistency of shavings while planing,​
tool grip and hand support,​
tool rest height/position,​
arms/foot placement,​
knee bending/leg movement,​
the three coordinated motions for coves with spindle gouge,​
the precise skew edge clearance needed for deep v-grooves and facing cuts,​
effective NRS use,​
hand a different tool to try,​
some not-so-obvious ways to correct things,​
different suggestions depending on the person,​
etc, etc.​
When beginning I'm far more interested in success than perfection so I don't overload with too much thrown at them at once! Baby steps.
I always ask if it would annoy them if stand close enough to look over their shoulder and the answer has always been No! That's what they came for.
After I see the basics are understood and progress happening I go do something else and let them practice and experiment until they have a question. Or when it's time to start on some variation. Or if a different approach is needed after I look at their practice pieces! :)
BTW, one person with some turning experince but not with spindles simply could not get the idea of moving the body instead of the arms for planing with a skew. This was even after repeated reminders. The arm motion was too embedded - the old canine, new tricks issue... I'm always excited to teach a beginner with a blank slate!
Folks, I want to start a new thread but I cant find new thread buttn?
On my computers, I
1) Click on the blue word "Forums" below the AAW logo near the top left of the screen.
2) Scroll down until I find the sub forum in which I want to post (Woodturning Discussion, Off Topic, etc).
3) Click on the name of that sub forum.
4) Click on the orange "Post Thread" button near the top right of the screen.
I use FireFox if that makes any difference.
I'd have to check the iPad (with Safari) later, but I think it's the same or similar.
I can't imagine access the forum on my phone. I think it might require better vision and more patience than I have at 3/4s of a century old!
BTW, one person with some turning experience but not with spindles simply could not get the idea of moving the body instead of the arms for planing with a skew. This was even after repeated reminders. The arm motion was too embedded - the old canine, new tricks issue...
Agreed, the 'lathe tango' is the one of the hardest aspects of turning to teach. As soon as they start to concentrate on their hands and the tool they forget they have legs.
If I'm ever watching a live turning demo, which I rarely ever get to do, my preferred position is behind the demonstrator where I can see and observe their whole body movement. I don't need to see their hands or tool position to know what they are doing, I get that from their whole body motion. Few videos capture that.
I spent a week with some well known turners and had my choice of where I stood behind them while they were turning because all the others watching were in front of them. On one occasion Raffan asked me if I could see OK... yes thanks Richard, I've got a very good view from here of your muscle memory gained from years of turning that you have forgotten you have. He was amused!
I don't teach woodturning other than to family members (mostly my grandchildren) and a few friends and I always begin with the lathe tango. I get them to mime a long spindle cut or sweeping cut around the outside of a larger bowl with a stick tool in hand and when they get to the end position of the mimed cut I give then a little nudge from behind. When they stop losing balance I go on to the ABCs... :)
On observing other turners, we all do it. Well, at least when the best get together they do. If you don't think you can learn something from other turners, you probably won't!
