Any experience with heat pumps in the shop?
Cheltenham, PA
I am thinking about heating/cooling my 300 sq. foot shop with a split unit heat pump . I have asked one HVAC tech what he though. His response was that it would probably work, may need to clean the inside air handler filter once a week. I am wondering if anyone has a unit in their shop and how it has worked out for them.
I have one, it works great. Woodstove for backup/supplemental heat. You do need to clean the prefilter regularly, get the coils professionally cleaned periodically and control the dust level in the air as well as possible
I had a heat pump installed when I built my shop maybe 9-10 years ago. My shop is about 1400 sq ft so my HVAC guy sized a 1.5 ton system with outside and inside components. I built the walls with 2x6s for extra insulation; the heat pump keeps the building as warm or as cool as I want with ducts to the different rooms. The climate here in TN is a somewhat warmer in the winter that when I lived in PA, if that makes a difference. I keep it fairly warm in the summer and somewhat cool in the winter to save energy costs but it's always comfortable. Since I process green wood into blanks, dry, and store wood I really like that it keeps the humidity fairly constant.
I do have to keep the filters clean but have to for the big heat pump at the house too. I use a central dust collector in the shop so the filters don't get clogged with wood dust floating around.
I also have a heat pump. I turn it off when doing something that makes a lot of sawdust to cut down on the frequency of cleaning the filter. Make sure you install a surge protector. I did my own installation and didn’t think about that. Cost me a bundle when we had a brown out!
I was tired of hauling/stacking pellets, so I installed my own a couple years ago. My shop is similar size and a local HVAC guy came out to give me a quote and said it would never work and tried to talk me into a radiant ceiling propane heater instead. He said it would be about $4k. 😬 :oops:
I got one on Amazon for about $500 and also ordered a vacuum pump for about $100. It runs on 110v so install was a piece of cake. I installed an outdoor outlet next to it and plugged it in. I extended the porch of my shop with a few pavers and set the outdoor unit on them. It drains a lot in winter, so I had to put some bricks under the feet. I should've hung it on the wall, but didn't because i thought it would be noisy. It's not at all; whisper quiet. I do wish it could be set lower than 60° in winter, but it's really nice to not be messing with ashes and pellets or a cold shop. I also gained enough floor space that I added another lathe. :cool:
My shop is heated with a gas furnace (ceiling hung) and cooled with a window AC when needed. But I still have on my list getting a mini split installed. There are lots of examples of folks who have done this in a woodworking shop and had no problem. The occasional cleaning mentioned above is the only downside, the lower cost of conditioning the air is a bonus.
One thing about central heat and air - the HVAC companies typically don't let you install or even help install, probably since they want to make sure it's right since they'll be responsible for it. But to save money, it doesn't hurt to ask.
When contracting for my shop, I asked the guy who came out to size and bid the job if I could save some money by doing some of it myself. He went back and asked the owner, who said no.
Then when the owner came to measure and do the actual deign, including the ducts and plenum, he started looking around and asked if I built the shop myself. Told me if I installed the inside components, ran insulated ducts to diffusers, did the wiring, etc, it could save some money! I guess without seeing all that he had imagined future problems and conflict if someone installed and botched things. After seeing what I'd built he offered me $1100 discount - sure, might be fun!
They supplied all the pre-formed plenum, return filter housings, ducting, diffusers, rivets, sealant, insulation, tape, and even loaned a crimping tool. It took me a week or so but I cut and framed as needed, ran all the electrical, installed the plenum and inside unit, cut the holes in the ceiling, insulated and hung ducts, mounted diffusers in various rooms, mounted the outside unit on a concrete base, the inside controller, did all the electrical. Nothing was difficult. Their guy came back and soldered the copper, charged with coolant, connected the wiring, and tested the system.
This was a company I and friends had used before so they knew me - another company might not have done the same. Other bids I got (for the same Trane heat pump) were twice the cost. Pays to shop around. I found the most popular HVAC company in this area for residential were the most expensive. If you want to find a reliable and reasonable HVAC company, maybe do what I did and ask a good architect friend who designs and gets things built - they know all the contractors, structural engineers, material suppliers, regulations.
One thing I discovered about outdoor breakers - the big outside unit at the house unit at the house uses three. Even in a quality outside box gradual corrosion on the terminals can increase resistance, increase current draw, and evenutally destroy the breaker. I learned to I coat every terminal, inside and out, with dielectric grease to keep the moisture and air away. (available at any electrical supply house)
I do call the HVAC company every few years to inspect and test pressures and function both at the shop and and the unit at the house.
Of course, a window unit is trivial to install and a mini-split not that much more. The thing most of us can't do is the refrigerant charging and leak testing. A good friend installed his central heat/air system for house and garage completely by himself - bought the charging and test tools and everything. But he was a lot smarter than me.
I have a 12k BTU Mitsubishi minisplit for my 24x24 garage. Costs around a dollar a day to heat in the coldest parts of the winter, and half that to cool in the summer. Probably $150 annually to keep it between 68F-58F. Garage and door is old but insulated, and I installed extra weatherstripping around the door to reduce drafts. I still need to blow a bit of extra insulation in the attic space. Single-head units are very easy to install DIY, just rent a vac pump from an autoparts store and let it go for a good couple hours, and check that it holds for a good while. The unit itself comes pre-charged, so it just needs vac'd lines.
If you want to heat in a colder climate, you should choose a unit that has reasonable cold-weather performance. HSPF will indicate that.
As for dust, I assumed I would need to build some kind of pre-filter for it, but put that off at first. I found that the unit simply doesn't accumulate dust as I thought it would, even when my shop is very dusty. The little mesh filter is easy to clean and will load up periodically, but the coils themselves remain clean. If you're in a warmer or moister climate, this might not be the case, but at this point I don't plan to do anything but blow the filter out every few months.
All of what Kevin said. My shop is setup for excellent dust collection, but not every process is going to be amenable to that. Most relevant to this forum, I don't really have DC setup for sanding at the lathe yet (the ducting is in, but I still need to solve the "last yard problem" via a collection hood and hose). No problems at all with the prefilters or coils getting gunked up, and I do get it serviced. It probably helps that the head is in a corner of the shop near the door, which is outside the immediate blast radius of the messiest operations (sanding, sanding, and sanding).
I have one mini-split head inside the shop, with the compressor right outside – it's a Mitsubishi system. When all this was being planned, I realized that we could also add a couple of extra heads on that system for the main house. That resulted in some wonderful improvements to this weird old house's overall HVAC setup. (There was a daylight basement expansion done decades ago by prior owners, but all of that was outside the original ducted system's reach.) Related, when the shop space was being rebuilt during our remodel I made sure the walls were insulated. There are two garage doors which were replaced during that work, also now insulated.
It's amazing to come into the shop whatever time of year and find comfortable working conditions, more stable humidity levels for wood, and very little maintenance required for rust-sensitive things like machined cast iron surfaces and tools.
Thank you to everyone who has shared their experiences. I will be going ahead and install a heat pump. I will be doing the work myself. Will now go ahead with the research to find the correct unit for me. So far it seems like 7 to 8000 BTU would work but smallest unit I can find is 9000 BTU. I think that will be fine but I want to talk with some tech people.
I found on-line calculators that take input like square-footage, floors, windows, R-value in walls and ceiling, and climate and estimate the BTU requirements. Might also contact a small, local HVAC shop and see if they will calculate and maybe provide consultation for a small fee.
I'll give you another option: PTAC (Packaged Terminal Air Conditioner) PTAC's are found in hotel rooms everywhere. you have to cut a hole in the wall to install a PTAC "sleeve" but once done any PTAC will slide right in. My 24X24 shop has a 15k BTU unit that heats and cools. I'm in Hot Springs AR. Mine's 12 years old and still works great but if it ever fails there are numerous manufacturers and all PTAC's fit into the same sleeve back bench.jpg
I'll give you another option: PTAC (Packaged Terminal Air Conditioner) PTAC's are found in hotel rooms everywhere. you have to cut a hole in the wall to install a PTAC "sleeve" but once done any PTAC will slide right in. My 24X24 shop has a 15k BTU unit that heats and cools. I'm in Hot Springs AR. Mine's 12 years old and still works great but if it ever fails there are numerous manufacturers and all PTAC's fit into the same sleeve View attachment 80927
Dave, is the PTAC self contained with the condenser and air handler all in that one unit. Is it as energy efficient as a split heat pump? Something new to look up. I will check it out, thanks.
I have a Mitsubishi mini-split for my 24’ x 30’ shop with 16’ ceiling (at the peak). It heats and cools well. Do keep your filter clean, it keeps it efficient.
Like John I built with 2x6 walls**, and the non-ventilated, cathedral ceiling** is 2x10s, with blown-in-batt, and two layers of 1.5” R-Max between two layers of sheathing under the roofing material.
**(I sealed every stud bay and ceiling bay before insulating so there is no air movement - making the insulation more effective)
The shop I built seven and a half years ago is separate from our home (which was built in 1959). I don’t need to start cooling the shop for at least a month after the house AC gets turned on, and likewise don’t start heating till a good month and an half after the house needs heat.
Pete,
I thought mine only went down to 61*F, until I read the manual!! There is a vacation mode so I can leave it at 50*F when I am away in the winter.
I was curious and looked up what I bought. It's a 12000BTU, 115V, 20 SEER2
Pat, not seeing any vacation mode setting, but that would be ideal. I go thru spells that I'm not in the shop and a lower temp would be really nice. It's not that bas bad cost-wise to just keep it at 60 though.
When I built my forever home and shop, I asked the HVAC guys about this very question. They were not sure. One suggested putting other filters over the main intake to "prefilter" the air going into the main thing. That seemed to work. I never use mine though. I heat with a wood stove in the winter, and never use the air conditioning since it cools off enough to keep the shop temperate during the day hours.
I have a "ducted" mini-split. The HVAC unit is a Mitsubishi 12K unit and the ducted portion is a Mitsubishi option. Mine is ceiling mounted due to late decision to use this option. My builder had planned for a PTAC unit, but due to my concern over filtration issues I found and made the change to this unit. If I had planned for this originally I would have positioned the ducted unit in the attic space. It allows for a large standard filter. My shop size is 20 X 20 with 12' ceilings. I have been very planned with heating, cooling, and managing the humidity in coastal North Carolina.IMG_4120.JPG
all self contained. Mine is an LG but they are getting out of that line of product but here is one at home depot same output as mine (15,000 BTU) or google packaged terminal air conditioner.
I have just about killed my window unit with dust. It has a tray inside that collects the condensate and a pump that sends the water to the outside of the unit to help cool the compressed refrigerant. The dust killed that pump so the whole unit doesn't work so well. I'd like to put in a new unit of some kind, but I would really want the air intake to be totally dust free. I that that would require a central air or ducted mini-split, but my shop is only about 198 square feet. Not at all sure where to go with this.
I just had a 33K mini split put in to my new shop. I built a filter box for the inlet. Has 2 16”x20” filters on the front and 2 14”x20” filters on top (cheap furnace filters from HD). So far, so good.
Mini-split all the way. Mitsubishi Electric, 2 ton (24,000 BTU) unit. Provides heat in winter and cool in the summer. Simple install by professional HVAC folks. Warranty: 2 yrs labor through HVAC folks; 10 yrs parts and labor through manufacturer. - John
I put a mini split in my new shop. Have not had severe weather and just getting Dust control installed . So far it has done what is needed. Installer suggested a pre filter. I ordered some filter material which I lay on top and in front of filters. I noticed yesterday I need to clean the material. SHop is 30x40 and the concern was that the fan would not cover the area. I have two air cleaners mounted to circulate air forward on one side and backwards on the other. If that does not circulate I figure to install some kind of fan in ceiling.
I have a Mitsubishi Electric heat pump for my shop, 2 head, 1 for shop, 1 head for 4 season room in western Wisconsin. Works great to about 15 degrees in winter, at which time efficiency decreases. I use a plug in 220 VAC 5,000 watt heater when needed. The shop is insulated fairly well, with cement floor. shop size 13' X 12' X 7.5' ceiling height.
Works well as AC in summer.
I put a Mr. Cool diy mini split in my 500 square foot shop 2 years ago. Its an easy install with no need for a vacuum pump. The line set has special sealed connectors and are pre charged. When you tighten them down they open up. It took 2 people half a day to install and a couple hours to do the electric run and disconnect to the compressor.
My enclosed shop is a one car drive-in garage. Even at cold weather in SE TN, it is never under 60 degrees. BTW, a new heat pump made a huge difference in the monthly bill. I keep one vent open as the basement, shop, den are all tied together. A portable heater can raise the temp to about 70 if left on long enough.
Heat pumps them new fangled things? Nah, don't have one, anyway I have too much heat most times of the year. I have natural source of cooling, my shop is situated East to West and I live on the East coast very close to the beach. I open up the doors at each end of the shop and enjoy the sea breeze.
But if the wind blows west to east, that means it's coming off the desert, hot and dry. The wind temps match the static air temps, the other day we had a westerly breeze :) 43C the nearest thing to a natural fan forced oven. I have been known to give turning away on those days, but still the finishes dry well. 🤣🤣🤣🤣.
I'm a month late to this discussion, but another option would be a MagicPak all-in-one heating/cooling unit, it is not a split system requiring a separate, exterior condenser unit, or multiple heads such as multi-branch mini-splits/heat pumps. These have gained huge popularity in apartment/condo construction over the years to provide a central heating/cooling system for apartments, and to get away from boilers and room air conditioners. They do utilize duct to deliver conditioned air to individual rooms, or for multi-outlet points in a large room such as a workshop (run a trunk down the center of the ceiling and have multiple supply registers installed on the length of the trunk). MagicPak is a subsidiary of Lennox.
I would consider an electric heat/cooling model installed in a well insulated shop environment. In my area (east central MN), gas is cheaper than electricity, but electric heat is 100% efficient in that no heat energy is lost to the exterior with the exhaust of a fuel-burning heater.
I have a heat pump. Shop is an enclosed one car garage on the basement of a split foyer; outside wall is concrete block. One time this winter in SE TN has the shop temp gotten below 60 degrees. I keep an electric heater to boost the temp up a bit. Left it on and temp got up to 68 degrees!
Be aware that these air to air heat pumps lose efficiency as the outside air gets colder. Mine are designed to operate down to -15F but they use a significant amount of energy to keep the exterior coils from freezing up with condensation. We had an extended cold spell with night-time temps below zero earlier this month and decided to heat with just the woodstoves. The woodpile is looking bare but the electric bill is a lot lower than it might have been.
How true. Both of my heat pumps use electric strip heaters that kick in when the thermostat decides they are needed. That does increase the energy cost during a cold snap but my Lovely Bride would rather be poor than cold.
Fortunately, TN is a near-perfect environment for heat pumps. The HVAC company can advise for other locations.
The real trick is to find the right HVAC contractor. Some I contacted seemed expensive. I finally wised up and asked an architect friend for a recommendation - he told me the one he uses at his house, in his company, and that he recommends to commercial and homeowner clients! The cost of the two high-end Trane units we had installed was 1/2 the cost than that quoted by the local company many in the area use. (That evil company wanted $300 to come out and replace an internal fuse in our old unit - I replaced it myself for less than $2.)
If you go with a heat pump pay close attention to the filters! (And pay the tech to inspect and test every couple of years.)
I sure wish I could heat my house with wood. We did so for the first few years and the very efficient Vermont Castings stove downstairs was enough to heat our entire timber frame house all winter without the heat pump. However after a couple of years my lungs disagreed so we had a new heat pump put in. (My lungs are always doing things like that to me, starting before I was 10 years old!)
