Ball-bearing bandsaw guides and wet wood
Moscow, ID
I have a Minimax S45N 18" bandsaw that has ball-bearing guides. I love everything about the saw except the guides. It cuts great, has plenty of power, and has the best dust collection of any bandsaw that I've used. But any time I cut wet wood for turning blanks, the moisture get into the lower ball-bearing guides and causes them to seize. Often, I can get them functioning again by spraying them full of penetrating oil and spinning the bearings by hand until they loosen up and start working again, but that's kind of a hassle. Has anyone found a better solution to this problem? As far as I can tell, SCM/Minimax doesn't offer ceramic guides for this model, and Space Age Ceramics doesn't have retrofit ceramic guides for it. I could just leave the bearings alone and think of them as round guide blocks rather than ball bearing guides, or I could sell the saw and buy a Laguna or another brand that has ceramic guides. Has anyone found another solution that works well? Thanks!
Ball bearing (side-blade) guides often quit turning because of build-up on the outer race, especially with wet wood. That's why they are typically considered a second-rate solution.
Tim
Tim
I use a Rikon 18” and cut many hundreds of blanks from wet log sections for drying. The ball bearing guides, both side and thrust, never seize up. I replace them every few years just for fun. I’d have to look to see what kind of seals they have.
I keep them adjusted and use powerful dust collection AND upper and lower tire brushes which help keep junk away from the bearings. If I occasionally get buildup of gunk on the insides of the blades when sawing particularly sticky wood, I clean it off with a tool I made, while the saw is running.
(Do the same on my Woodmizer sawmill when sawing sappy Virginia pine.)
Stationary side guide blocks tend to scrape any residual swarf off a blade. In contrast, roller side guides tend to mash swarf onto a blade and the rollers themselves. That’s why you have to occasionally clean your blades. Stationary side guides such as those sold by Wright are considered some of the best.
Tim
Bearings are generally available with a couple of different sheilds (or no sheilds) it may be worth contacting a local bearing supplier for advice.
Some bearings are also available with ceramic balls but I don’t know if they’d be suitable for this application.
