Band Saw guide bearings
Delray Beach, FL
I was changing the blade on my 14" Grizzly and I spun the guide bearings before installing the new blade.
The lower side bearings would not spin so I removed them and ordered new. They are 608 sealed, the same size as roller blades it seems.
I removed the seal to see the problem, it seems wood dust can get anywhere, even sealed bearings. (most likely lungs also)
Seals removed for curiosity and picture.
Stu
Curious you just posted this Stu. I was going over my old Delta 14” saw and found that the lower guide bearing was seized. Just got a package of 10 bearings (6200Z) from Amazon for $10. McMaster-Carr had the bearing I needed for $5 each, plus shipping. I figured I could replace it several times for less cost, even if it’s not as good a bearing.
Been there done that and yes you will be changing them soon.
Those are not sealed bearings, but rather a shielded bearing, a sealed bearing will have a gasket on the shield that rubs on the inner race.
It may not be best idea to buy bearings on price These days the inexpensive ones likely are third world of unknown quality.
I just replaced the bearing in the lower drum of my classic Delta 6 x 48 sander. The originals were shielded. I went to my favorite local bearing house to get replacements. They had both shielded and several brands of sealed in stock. The clerk asked the rpm. I made a guess on rpm based on the pulley sizes. He suggested a sealed bearing that was rated for up to 5,000 rpm. Great.
If I had bought sealed bearings online who knows the upper rpm limit? In years past I don't recall the sales people being quite so thorough. I know I had previously (years ago) been told not to replace shielded bearings with sealed bearings because the seals couldn't tolerate the higher speeds.
