bandaid for burls
Huntington, VT
This leaky vessel was stabilized during hollowing by attaching a wooden bridge across one of the voids with hot melt glue. The bridge was cut on the bandsaw and scribed closer (not very) with a spindle sander. Removed after sanding with help from a heat gun. I learned this trick from Tom Dunne of Middlebury, VT.DSC_0672[1].JPG
I will try your bandsaw ring method another time. Thanks for the suggestion. It might help with overall rigidity- a voidoid piece like this tends to vibrate a lot. I have used this bridging technique a couple of times when a loose section started flapping.
A very clever technique, now to try and remember it if a similar problem presents itself.
Would you mind explaining your hollowing technique? It looks like there is I steel rod/tube were I would I would insert the hollowing tools.
The photo was taken after the hollowing process while mounted on a Kelton mandrel for removing the tenon. I turned the outside between centers using an Elio drive center and the inside using a Talon chuck, Clark hollowing bar and several different cutters. The piece is about 6.5" high, 11" diameter and averages 1/8" thick, with a 1 1/4" center hole. I meant to turn it thicker, but the chatter overcame my intent. I cease to be amazed how little substance can remain in shapes like this and still hold together. I don't usually name pieces, but this one might be called "fear of flying" or maybe "rm w/vu".
