Hi Bill.......I'd love to see photos of your shop's 9 lathes in this thread:I must be the luckiest woodturner ever as all nine of my lathes use the screw clamp style system and I have had no problem with marking the tool post or anything else with any of them including my Powermatic and my 16" Jet. Except for the newest which is about 2 years old they are 14 to 23 years old and have at least been used for hands on by others 2 or 3 times a year without problems and all with their original tool rests for the most part. Again I sure am lucky![]()
I believe ONEWAY has the best banjo. Definitely the best I have used.The banjo on this lathe is the only major gripe that I have about the machine. The post dents and mushrooms………grrrr. Wondering where to look for a replacement with a clamping style holder instead.
Jet has revised the banjo/clamp to a wedge style system on the new lathes. Not sure how it compares. I guess I have to go look at one in person. Shucks.Yep- Many banjos can be interchanged , possibly with modifications if need be, or correctly sized ones from Oneway (all they need I think is spacing between bed rails? - check the Oneway link in GR's post above) - I replaced my flimsy Harbor Freight lathe banjo with a used one from Laguna that someone on these forums sold me I took a chance at it since it had 1 inch post (the HF posts are 25mm) and I'd just bought someone else's 1 inch post oneway tool rests. To make the Laguna fit I had to fabricate / jury-rig a bed rail spacer clamp (basically a really thick washer filed to just fit between bedways and then another bigger fender washer to clamp down to bedways) and it works so much better than the HF banjo , and the laguna has a "pinch clamp" type lock so it doesn't deform or damage tool rest posts . Seeing your Jet Banjo, now I'm wondering if that is the typical one I'd find on a new JWL-1842.. if so, I may re-think the 1842 as my target for a new lathe...
Wow. That looks like it just may be your problem!Reading everyone’s replies has me wondering if the issue is more the original cast tool rest. The amount of deformation isn’t catastrophic, just enough to inhibit the free movement of the post. If I move to a hardened post, will I have enough “grab” with the screw clamp versus pinch?
Here it is Odie.Hi Bill.......I'd love to see photos of your shop's 9 lathes in this thread:
Photo of your workstation
How about a photo of your main turning workstation? It's nice to see what folks came up with for storage, accessibility.www.aawforum.org
I sure wish I had the room for another lathe, but all I have is aisle ways, with no room to spare!
I was hoping for a few more details, but thanks, Bill.Here it is Odie.
Odie there are a lot more photos in the "show your shop" thread.
Couldn't find them with a search, Bill......If you could supply a link, that would be helpful.
thanks
OK....got it now, BillOdie this is the thread and I'm below your shop photos.Photo of your workstation
Agreed. I used to crank down the banjo screw on my General 260 and even lengthened the tommy bar but never dented the tool rest post. I wound up with a Oneway banjo which grips the ways and tool post with ease. Fighting equipment is a losing battle.Looks to me like you grossly over tighten that bolt! It takes a lot of pressure to deform any kind of metal that much! You can epoxy a bit of brass rod to the end of the bolt, or put a slug of brass in the hole before bringing in the bolt.
Not necessarily the case... if you have an ill-fitting tool rest or banjo (or not perfectly round) you'll experience gouging and scoring as the tool rest bears the pressure of the tool in use on only a couple or three small surface areas - The tool rest will shift, twist, slip down and more, all that pounding really does a number on any kind of metal - even with brass or aluminum screw tips (ever seen a cast iron engine bore shredded to pieces by a broken aluminum connecting rod? I have!) In order to make the tool test stay in place, on some of these poorer-quality banjos or tool rests, you just about HAVE to crank down as hard as you can (and even then it does not always hold) Not everyone has had to deal with a crappy, inferior quality lathe like some of us have had to...Looks to me like you grossly over tighten that bolt! It takes a lot of pressure to deform any kind of metal that much! You can epoxy a bit of brass rod to the end of the bolt, or put a slug of brass in the hole before bringing in the bolt.
Newbie question here...I am using the original cast iron tool rest that came with my Jet, and somehow I dinged it. I cleaned it up with a mill file, but it got me going down a rabbit hole on what other tool rests I should consider. I can appreciate upgrading to the Robust comfort rest with a hardened rod, but do you recommend investing in interior/exterior curved rests too? I wonder if it's more of a skill building exercise to get a clean cut on a curve with a straight rest.I have a variety of tool rests. Some from Robust and some from Bestwoodtools and several hand made using drill rod.
Depends on what and how you turn.can appreciate upgrading to the Robust comfort rest with a hardened rod, but do you recommend investing in interior/exterior curved rests too? I wonder if it's more of a skill building exercise to get a clean cut on a curve with a straight rest.
Raising the tool rest alleviates the problem of the tool handle hitting the bottom of the rest during pull/slicing cuts and shear scraping.I’ve used the longer comfort rests a lot in demos. They interfere with pull cuts. When you drop the handle the tool hits the bottom of the rest and comes off the top of the rest. If you plan to do pull cuts you will have to switch to another rest
Not necessarily. In many cases, I prefer the Robust low profile rests, which provide easier access at steeper angles, especially for spindle work. The comfort rests may or may not work. The profile of the cast tool rests with the angled surface below the top are very ill-adapted to making cuts with the gouge at a very steep angle. When teaching classes on Powermatics, I replace the cast tool rest with a Robust (or similar) rest before class begins.Raising the tool rest alleviates the problem of the tool handle hitting the bottom of the rest during pull/slicing cuts and shear scraping.
I was wondering about the lengths. The one I have now is 14" long. I have only been turning bowls, and it is sometimes a bit cumbersome. I can't imagine going any longer.On a more basic level, it is useful to roughly match the length of the tool rest to the dimensions of what you are turning. The stock tool rests on full-size lathes are far too long for working comfortably on smaller pieces. It is useful to have rests of varied lengths.
It’s not the handle it is the bar. It’s much more comfortable to just use another tool rest.Raising the tool rest alleviates the problem of the tool handle hitting the bottom of the rest during pull/slicing cuts and shear scraping.
