Baxter Thread Master
Status
Not open for further replies.
Nebraska
I have a new Baxter Thread Master for sale that was used to take measurements off of to fabricate a custom mount for a customers new lathe. All of the accessories are new and still in the bag, there are (2) riser blocks for this unit which will work on a standard 12" swing lathe and with the additional riser block would work on a 16" swing lathe. This is the standard BTM-12.5 thread master with a SH1x8/16 TPI spindle assembly. Also comes with (2) 1x8 2" face plates.
1....Basic Thread Master
1....Spindle Head (Your Choice of 1" x 8TPI)
1....1-1/2 Riser Block
1....1-3/4 Riser Block
1....Threading Head (16 Pitch)
1....NEW Bed Stop
1....3/4" Thread Mill with 3/8" Shank
1....3/8" #2 Morse Taper Collet
1....3/8-16 Draw Bar for the collet
1....Set of instructions
bestwoodtools_2232_4570596
Price is $375.00 plus shipping.
Normal retail is $580.00 for all of the accessories and new threading unit.
Contact mikeee12345@aol.com or PM me on the forum.
Bill,
The shorter riser block would most likely work on the Jet mini, the Jet Mini should have a Morse Taper #2 which this system is supplied with that size of collet to hold the cutter. The other variable is the gab between the bed ways, this kit comes with an 1-1/4" and an 1-3/8" gap indexing spacer that aligns the jig to the lathe ways. Just so long as your lathe ways gap exceeds 1-1/4" the jig should mount properly, I tested this on a 1-1/2" gap bed by indexing the jig against one of the bed ways and clamping the jig down and the jig did not move between the ways while using the smaller 1-3/8" gap spacer. Different sized bed ways indexing spacers are readily available from Baxter as they kit the proper sized one with each system that gets ordered. Baxter also makes various dimension riser blocks to raise or lower the thread taper spindle block for various swings on different lathes.
Mike J.
Status
