Beading?
Baltimore, MD
Aside from utilizing a dedicated 'beading' tool, does anyone have a video clip that demonstrates how to create a bead with any of the 'traditional' tools? I've seen it done with a small bowl gouge, spindle gouge, and even a detailing gouge but never a close enough view to discern what the turner is actually doing? thanks...John
Richard Raffan, using a spindle gouge:
View: https://www.youtube.com/watch?v=BtN81mIbwKQ
If you’re talking about face work, the Richard Raffan method beats anything else hands down. It takes a little practice, but once you master it anything else seems foolish
I can't imagine making a true bead with any bowl gouge. With a skew or spindle gouge you end with the flute being vertical. No way that works with a bowl gouge. Coves and beads are the groundwork for so much of what turning is in spindle work.
I do my exterior beadwork with the tip of a 1/2" 40/40-grind bowl gouge. I generally just have a single bead, though, rather than a whole series of them one next to the other. For that I'd want to use my spindle detail gouge.
The bead between the foot and body of this narrow-leaf ash bowl is roughly 1/16" wide, cut with the 40/40 gouge.
Kalia, that looks fantastic. This is the sort of detailing that I've struggled to learn, despite some coaching locally. Not sure I've tried with the 40/40 gouge yet though. Always another approach to the challenge. Thanks for posting.
Out of curiosity, what happened to your video?
I dont know. I had a problem where I had videos on two different accounts and couldnt straighten it out. A friend came over and started a new channel and transferred all my videos to the new channel. Didnt know that one was missing. Who knows what else is missing.
If you haven't yet tried grinding a gouge to 40/40, I highly recommend this video from Cindy Drozda.
View: https://www.youtube.com/watch?v=rhEewtRlkNA
It's the clearest explanation I've seen for how to do it accurately, and what to aim for. She also shows her similar technique for sharpening a spindle detail gouge.
Since the 40/40 grind leaves you with an 80-degree tip, you can get into some very tight spaces with it. At the end of the cut I do indeed have the flute completely closed to create that crisp edge.
And I have to ask if you're related to Peter and Mary Alice Amidon.
Love the shape/form of that piece...quite elegant. What would you say your wall thickness is?
I generally don't turn super thin since these are meant as functional pieces. This one is in the neighborhood of 5/16" thick, maybe a bit more.
That's exactly what I do...for my area, the stuff that sells best is utilitarian pieces so all of my stuff is food safe wherever possible. I find it works well for my local Farmer's Market where I sell my stuff.
Hi Kalia,
I've got the 40/40 down from a sharpening and using perspective, just that I had not thought to try it for turning beads.
I do happen to have a cousin, by the name of Peter Amidon, but not a Mary Alice, so I assume we are talking about different people. Probably related distantly, however.
John's video is really good: comprehensive and compact, all the tools and techniques in 15 minutes. I watched this a while ago and the tip that really helped me was to slow down, really slow down, even stop, in the course of executing the simultaneous rotate-lift-twist movement with the spindle gouge. Trying to learn that complex movement in one quick sweep was too hard for me, but when I realized I could just stop mid-stream and say "wait, I need to be lifted more" or "twisted more" or "rotated more", I was ultimately able to get the muscle memory to do it in one sweep.
