Best way to ebonize wood, and best wood to ebonize?
Aurora, CO
I've had a project in mind for a while: To turn a bowl (or bowls, rather) that have a black exterior, but their natural color on the interior. I've encountered a few pieces like this, always loved them. One approach, that I figure I'll try at some point but just not yet, is to burn the outside, and that is interesting, but not quite what I'm looking for.
I know that some woods, those containing tannins, can be ebonized in various ways by causing those tannins to blacken. I've done some research on this, and noted that ebonizing with certain solutions on tannin-containing woods, is not really going to give you a "true black" look like the charcoalizing approach does, nor a black that rivals say African Blackwood. I am really looking for a true black. I suspect that dyes may work here, although I am not sure what the best dye might be. Perhaps ink...I thought I came across someone talking in a video about using an ink to ebonize, however for the life of me I cannot find it again.
I'm curious what approach works best, to ebonize to a nice, solid, complete black, and which woods handle it best. I figure, if dye or ink is involved, the wood does not necessarily need to contain any tannins, but I figure some woods are probably better than others to soak up the right amount of dye/ink for the best results. Also curious about application technique, whether any kind of sealing first might be useful, etc.
Thanks!
I use India ink - usually on things like finials and goblet stems. You can check my stuff in the gallery - some (not all) of the rockets and goblets have maple parts dyed with India ink (others are African Blackwood). I get a pretty good deep black.
I think the challenge you're going to face with a bowl exterior when using dye or ink (anything liquid-y of any color) is bleed-thru. Depend on the porosity of the wood (or if there's micro-cracks etc), you might get black bleeding thru to the inside. Also around the rim (re-cutting the rim after dying could help). So testing on similarly-thick pieces of side- and end-grain of the same wood is probably called for.
I've had varied results with the iron acetate (vinegar & steel wool). Sometimes I'd get a great deep black, sometimes just blah grey (even with the same solution on a different piece from the same tree). So I don't bother with that anymore.
Seems like to me you'd get the best results with something thicker. Someone is surely going to suggest shoe polish, but I have no experience with that. Paint seems like the safest bet to get the color and maintain control over where it goes.
India Ink! That is what the video was about. Your results look excellent, just what I was looking for.
Good point about bleed through. That's why I asked about sealing... I guess it would depend on the wood and grain orientation. If I do bowls, I wonder if it might be better to do end grain bowls rather than the classic bowl grain orientation to try and prevent that.
The more common forms of ebonizing (iron acetate, is that where you steep steel wool in a solution for a while?) do seem to be hit or miss as far as how dark you get, which is why I posted the thread. I guess it probably depends on the amount of tannins in any given piece of wood, even if its known to have high tannins (i.e. oak). I like the look of the india ink, though. Will give it a try.
I like the look of cherry that’s been ebonized with iron acetate (steel wool dissolved in white vinegar). The trick is to apply a coat of black tea to boost the tannins just before you apply the iron acetate.
Here’s a bowl I did a while back that used that technique on the exterior. View attachment 85605
Beautiful. Simple, yet the contrast really does something for it! I had read about using black tea as an initial conditioner. How has your experience been with bleedthrough? Do you do anything to prevent that?
With any penetrative finish there will be a little bit of capillary bleed, but when I use this technique I always finish the outside (sanding and ebonizing) before I hollow the interior. That approach leaves a pretty crisp transition at the rim IME.
Here's a backwards colored from what you wanted. I did it because I was tired of trying to get the inside smooth. (hides a lot) There's a lot of bug activity visible. I'm calling it "rustic"
Dick Blick India ink.
The best woods for ebonizing, IMHO, are oak and walnut. Cherry will turn, but results in more of a dark gray. At our recent club meeting, where the demo was Ebonizing, the presenter used tannic acid from a wine making supply store, and any wood we tried got very black. I've used wet tea bags for the same purpose, but the wine-making tannic acid produced a very uniform and deep black.
One other choice to consider is Fiebings USMC leather dye. It's a potential disaster if you spill, but it also produces a uniform and dense black, on most woods.
With that in mind, the wood you choose might best be based on the contrast each gives between the natural wood inside and the deep black outside.
One note from experience--the result with ebonizing or leather dye will be a little fuzzy from raised grain, and the color may be blue-black (like Superman's hair is the old DC comics). After a light buffing with fine scotchbrite and applying your favorite film finish, you'll get a true black. (Sorry, no pictures, as the black pieces I make are given away immediately)
PS you might check with Vinnie Luciani on what he uses for the black background on his carved vessels. Maybe he'd even agree to a play date.
I like Fiebing's Leather Dye - USMC Black. I’ve not found a wood it won’t work with. Easy to work with. I usually apply with a foam brush. Have airbrushed it on a few times.
On HFs. I’ve used it on the inside of a few but have switched to golden airbrush opaque black on the inside.
If I finish the outside first the leather dye doesn’t bleed through but it dulls the colors on the outside a bit.
Camphor Leather dye applied with airbrush
Citrus - leather dye dapplied foam brush
Camphor golden opaque black airbrush background
I use the vinegar/steel wool solution on Oak and Ash and like the look that I get, but it is not what you are looking for. I love the appearance of different colors on the same piece of wood from medium brown to dark grey/black without masking the grain.
Yeah. I honestly don't mind that look, and I think it would be great for other pieces. But for the set of pieces I'd like to make, its not quite what I'm looking for.
I'm intrigued by the fact this is applied with an airbrush. Is that to achieve a certain look to the finish, or does the stuff not wipe on well?
Curious how well an airbrushed on finish holds up...well?
Do you finish to a higher grit? Wonder if closing off the pores a bit that way would help with bleed? I will be doing some experimentation here to see how it goes on a few types of wood. Cherry is probably the main wood I was thinking about using, I just like that warmer tone with the black. But I might also try with some maple as well. I hadn't planned on using any woods with larger more open pores...I do wonder if filling the grain a bit for such woods, though, would help with any bleed? Or would the ink just go right through any grain filler?
With Cherry, I usually sand to 320, then do the first round of ebonizing. Let dry. Sand 320 -> 400. Ebonize and let dry. Sand 400 -> 600. Ebonize and let dry. Hand sand w/ 600. Then apply your preferred finish.
Can you share any details about how to use the tannic acid? I guess you dissolve it in water (how strong of a solution?) paint it on the surface you want to ebonize, let it dry, then apply the vinegar/steel wool (iron acetate) solution?
You read too quickly🙂
I usually apply the leather dye with a foam brush. The dye is thin spreads easily with a foam brush to get a nice look easily.
With the first hollow form I airbrushed it on with the sandblast resist in place acting like a frisket.
Brushing with the resist in place would create bleeding under the resist.
Removing the resist shows the surface not made black.
I prefer the airbrush paint for doing backgrounds with resist in place. The paint sort of dries when it hits so it leaves a crisper border than the dye. Both work.
Airbrush dye and paint hold up quite well. I would judge equal to brushed on. It can be scratched through intentionally or accidentally.
I like to apply the iron acetate while the tannin solution is still damp. IME that elicits the best reaction.
I always get a chuckle out of the term "ebonizing". You're just trying to make the wood black! Whether you use black paint, black dye, black ink, etc., etc., etc., you're just trying to darken / blacken the wood. If you wanted to lighten (whiten) the wood by bleaching, painting, dyeing, etc., would you call it "Holly-ing" or "Ivory-ing"? ;)
I’ve always reserved the term ebonizing for the use of iron acetate. Not sure what else you’d call that; it’s not a dye, paint, or stain.
The same argument could be used for the term “bleaching,” though. You’re just making the wood lighter and there’s no actual bleach involved 🤷‍♂️
Yep.
The dilution should be on the jar of tannic acid, but it doesn't have to be precise. And it doesn't have to dry prior to applying the iron solution.
On the rare occasions where the ebonizing solution hasn't been dark enough for me, I've used tea bags. Just dampen one, press it around on the object, then the ebonizing solution. I think the wine shop material gives a more uniform result, and possibly darker black.
In my experience, the ebonizing does not create a uniform, solid black. The underlying wood's natural color variations will show through, with some areas a little brownish, some kind of grayish. To me, this is a more natural appearing result than paint or even the leather dye. If you look at ebony, it will often have the same gray or brown variations, so, to me, 'ebonizing' is an accurate term.
Of course you are right about that, Dean. But, if you read the OP's question(s) about making the wood black ("ebonizing"?) and some of the early comments of others about painting, dyeing, etc., you will see where I'm coming from with my comment.
Quickly grabbing a relevant comment I made on this same topic a couple of years ago on another thread:
I just happened across this recent paper (2023 Jan 30!) in the Journal of Wood Science, Iron acetate solution prepared from steel wool and vinegar for ebonizing wood by Robert Q. Thompson. It’s an open access publication, so the entire work is available on the web as well as via PDF download at that link.
This is the first really rigorous dive into the chemistry and application of iron acetate for ebonizing wood that I’ve found. There are a lot of details that will only interest those with a chemistry background, but there are definitely process tips that refine or even upturn commonly cited practices in the woodworking world. An example:
“Steel wool usually has an oil coating that you’ll need to remove before making the solution.” The reaction rate is not significantly changed upon washing with detergent and water or rinsing in nonpolar solvent.
or this one:
“Let the steel wool and vinegar sit for a week.” An effective iron ebonizing solution can be created in just 3 days.
Readers can fast-forward to the practical details in the “Conclusions” section, where the author provides a nice summary of where the study improves on the common folklore.
I guess its just a term that describes a process. Maybe it could be called "blackening"...? Doesn't sound as cool as ebonizing, though. :P Ebonizing basically says the same thing, a process to make something look like ebony (which is the word, or similar to the word, that refers to the color black in many latin-based languages).
me too Dave. I did some ebonizing the traditional way with steel wool and vinegar on walnut. Worked somewhat but not as black as I wanted and took a while. India Ink on maple is great for finials. Only knock on it is that it gloss. haven't figured out a way to cut back on the shine but I'm happy with it on the couple of pieces I've done.
Hmm, interesting that it is only gloss. I'm not sure that is what I want here.
What about dyes? Aren't there alcohol-based dyes? Anyone use anything like that to ebonize?
me too Dave. .... India Ink on maple is great for finials. Only knock on it is that it gloss. haven't figured out a way to cut back on the shine but I'm happy with it on the couple of pieces I've done.
Huh. I always shoot my finials with lacquer, trying for gloss. But my impression has been that the India ink by itself (Speedball Super Black, if it matters) seems sorta dull (matte) before that. Glossy when wet, but more matte when dry.
But since I'm aiming for glossy anyway, I haven't really paid it that much attention.
I always apply twice, with a sanding in between (since the first coat raises the grain usually) - sometimes the second sanding is wet-sanded using ink. Doubt that sequence has much to do with matte-ness.
speedball is what I use too.... as for the dullness,, I initially see that too, but I don't like glossy finishes so I use my own wipe on poly (50-50 MS and gloss poly) and add as many coats as need to get a little shine but still looks like wood. works for me. (I use speedball ink too)
