Hi, I've made a finial for a sea urchin ornament out of maple and wondered about colouring it black. I've heard of using black shoe polish or dye. The TransTint dye suggested seems expensive for my limited use. Any suggestions? Thanks, Jim
I wear nitrile gloves and apply with a foam brush.Thanks everyone, I found Fiebings Black Dye at a local Michael's art supply store. I am not sure what the USMC designation refers to?
Go Mounties!I. lots of folks south of the border won’t recognize RCMP.![]()
Leather dyes and India ink both work well. Fiebings leather dye is the most commonly available in the US. 4oz is about $8.; 2 oz of ink is about the same cost as the leather dye.
BTDT tip: Wear disposable gloves!
Thanks for your kind comment. I do live in Ottawa, ON, Canada.I wear nitrile gloves and apply with a foam brush.
Usually 1 coat is enough.
You are excused for not recognizing USMC.... lots of folks south of the border won’t recognize RCMP.![]()
BTDT = Been There, Done That!While we are working obvious acronyms, what the heck is BTDT, lol! BTW, that USMC black looks great. Is the Matt finish the end result or does that require another process.
I only have used the USMC black by Fiebings. Have not noticed any fading.I am wondering how light fast the Fiebings dyes are. Many years ago, in the 80's, I made custom Hacky Sacks. At first we used the Feibings dyes to add color to them. Leave your footbag (Hacky Sack is a brand name, like Frisbee...), and the colors would bleach out as fast as cherry wood gets a tan. So, have their dyes improved in that aspect?
On my ornament finials (icicles) I use hard stick carnauba wax while still mounted on the lathe. I usually use holly or maple and don't dye them but the wax should still work and bring up a nice shine. Many, many years ago I dropped a carnauba stick on the concrete floor and it shattered like glass into many shards of all sizes. Many of those pieces are narrow and sharp enough to fit into the narrowest nooks & crannies of your finial. Apply (rub) at high speed (same as my turning speed for finials) and buff off with a paper towel to avoid any disastrous catches that can occur with a cloth. Buff between your fingers and avoid any lateral pressure that could break a delicate finial. Try it.....I think you will like it.Any suggestions about the top coat finish on the spindle after it has beed dyed?
On my ornament finials (icicles) I use hard stick carnauba wax while still mounted on the lathe. ...
Go Mounties!![]()
