Blew it up HF
Orange, CA
Bought this cracked piece of desert ironwood. IMG_1008.jpegSure stinks when you turn. Wanted to turn a HF with a 1 inch opening. Had it almost done, was just finishing the bottom when BOOM! I had used some thin CA earlier in the pith cracks but it blew due to a bark inclusion that probably should have been CA’d. IMG_1002.jpegWall was less than 1/4 inch and pretty smooth and consistent. So I learned a lot but lost a pretty piece. IMG_1006.jpegIMG_1005.jpeg
That sucks! The piece I got had one big crack right thru the middle so I slit it with the band saw into two small bowl size. Could you slice it and add a bottom to it!
Fwiw I have a piece with a lot of cracks like this and plan to put in a vacuum chamber to fill the voids with resin. Much more work and expense, but much less likely to blow out
I would expect that piece to experience an unscheduled rapid disassembly, given its initial appearance. If I were tempted to turn it anyway I would wrap it thoroughly with plastic twine (stretchwrap) or duct tape before hollowing, and stay well out of the line of fire.
I saw those listed and thought, “man, someone is going to hurt themselves turning those”. Glad it was just the piece that you lost.
