When we use the expression ‘I turned a box’ what is the accepted definition of a “box”?
I think that there are definetly lidded cross grain boxes. Bowl to me has a curved bottom. If we look at the cross grain box for the February challenge from Richard Raffan, that is definetly a box. I do agree it can be ambiguous of course.I would say a container with a lid, generally turned end grain so the lid remains well fitting. If the container is turned face grain/cross grain, then I would call it a lidded bowl. I don't believe there is universally agreed upon terminology, though.
Bernie, good question!When we use the expression ‘I turned a box’ what is the accepted definition of a “box”?
End grain orientation verse's face grain can have the same issues especially if the pith is not included, since the same radial and tangential shrinkage rates are present. End grain with the pith included may not go out of round as much, but the overall diameter can & will change with the seasons causing the binding.One thing about grain orientation: Due to the way wood moves with moisture change, say from the seasons, an end-grain box, made with the grain running parallel to the bed of the lathe, is far more likely to stay round and stable with seasonal humidity changes. Boxes made from side grain, face orientation, are more likely to go out of round, some so much that an otherwise non-sticking lid can start sticking! The amount they go out of round can depend on factors such as the type of wood and how well and what the wood is sealed with, as well, of course, as the degree of humidity change in the environment.
You are correct. Instead of "far more likely to stay round and stable" perhaps I should have added "depending on the species, the specific tree and how it grew, where the end grain blank is cut from the tree, the size of the box blank, and other factors"End grain orientation verse's face grain can have the same issues especially if the pith is not included, since the same radial and tangential shrinkage rates are present. End grain with the pith included may not go out of round as much, but the overall diameter can & will change with the seasons causing the binding.
Apparently ChatGPT has not figured out if grain orientation is involved in the definition of a box, but recognizes there is a difference between a bowl and a box, but is unable to accurately say what that difference is. To define the difference by usage and not by appearance tells me that we woodturners are still one up. Probably not for long.Good answers
ChatGPT had this to say
A turned box is a small, lidded container made on a lathe, usually from wood but sometimes from other materials like acrylic or resin. The process of turning involves shaping the box and lid by spinning the material on a lathe and using cutting tools to achieve the desired form. Turned boxes are often used for holding small items like jewelry, keepsakes, or spices.
A lidded bowl is a bowl with a fitted lid, typically used for storage, serving food, or decorative purposes. It can be made from various materials like ceramic, wood, glass, or metal. The lid may sit loosely or fit tightly, depending on its design and intended use.
Apparently ChatGPT has not figured out....
The reaction wood may be neutralized but the thing we call figure will affect how the seasonal changes affect the confusion of radial and tangential movement on a box with a close fitting lid. The seasonal movement of a bowl will be unnoticeable as long as it can move without checking.I have had box blanks drying for about 2 years now, time to finish them up. since they have been roughed out, I figure most of that stress has been removed. With my bowls I turned from it, the more they warp, the more I like them!
I gave up reading anything the so called AI algorithms output. Some was obviously incorrect. I suspect everything written here and elsewhere is copied, parsed, stored, then searched, voted on,and a compilation regurgitated.
