Bradford pear source
Very prone to cracking , just like any fruit wood, remove pith ,cut over size and seal right away. I love Turning Bradford pear especially for anything that has a lot of detail, like basket illusion pieces, cuts well, polishes easily and has pleasant pinkish/ reddish brown color when dry.
Not sure what you are saying about removing the pith. These are small branches and logs up to about 16-18 inches diameter.
The pith is the heart /center stem going all the way up the tree, its the first area that cracks will develop from . You should also try and select logs with less branches coming out as the branch areas will be prone to cracking as well , below is a cut diagram , the pith / heart gets thrown away and the rest gets used 1775433729548.png
The pith is the heart /center stem going all the way up the tree, its the first area that cracks will develop from . You should also try and select logs with less branches coming out as the branch areas will be prone to cracking as well , below is a cut diagram , the pith / heart gets thrown away and the rest gets used View attachment 86952
Great picture.
