Here are some pics of my brazing process for anyone interested in the brazing their own bandsaw blades cut from coils stock:
**Blades can be cut to link from coils using tape measure and tin snips.
First word of warning: Suggest grinding at a pretty high angle on a smooth wheel to avoid a catch.
Don't hold the blade down toward the platform or it could be grabbed if it gets caught between the wheel and platform.
First step is to grind a kerf about 3/8" so ends overlap when brazing.
Then clamp blade to a piece of angle iron or aluminum with a sharp 90 degree angle
(rounded inside angle are no good) with a small section removed brazing.
Add solder paste a a small section of silver solder ribbon that is a little wider than the blade.
Don't be stingy because it's pretty cheap per blade.
Heap blade and solder with Propane or MAPP gas torch until solder melts. It's about done when blade starts turning red.
Slowly back the heat away.
Clean up solder joint with a cheap (i.e. Harbor Freight) diamond file.
Note: I take a handheld air grinder to smooth out the joint after mounting it on my bandsaw so it runs smoothly through the guides.
That's it. Process takes about 5 minutes from start to finish.
