Regarding the oven--toaster oven--new or used, expensive or cheap--most stabilizers use them, but i found the few i tried to be difficult to control temperature in a narrow range. Found that temps would continue to increase (by 100f to 125f) AFTER the burner shut off. Closest i got to maintaining 225f for drying was with a digital PID set to on at 154f and off at 156f.
Found an old lab oven locally for $50, heavy with lots of thermal mass--and draws like 4 amps instead of 15+ for the toaster ovens. Very stable temp, very efficient, and cool to the touch outside. Only downside is that it takes an hour or so to get to 225f, but on a 24 hour cook i'm okay with that.
Really, the toaster ovens are made for short uses (making toast or Eggo's), not for the 12-24 hour run that it takes to bring moisture in wood close to super-dry state needed to keep steam from forcing Cactus Juice back out. After both my nephew and i had fires in toaster ovens about a month apart--i trashed the one i had. Lab ovens are used in many medical & dental processes--and older ones are available almost anywhere there's dentists, hospitals or whatever. (mine still has a St. Jude's inventory sticker on it and is probably 20 years old.)
Stabilizing is amazing and opens vistas--i'm just glad i didn't burn my garage down using a toaster.
