- Joined
- Jan 27, 2005
- Messages
- 13,209
- Likes
- 5,813
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
The grinding wheel on my Tormek is wearing down close to the minimum diameter and instead of getting a new standard grinding wheel I was considering the idea of getting a CBN wheel. The thing that had been preventing me from going ahead was that the available grits in a 10" wheel would mean settling for an edge that wasn't much better than what I could get by putting a CBN wheel on my dry grinder.
I was aware of the new higher grit CBN wheels that Woodturners Wonders had so while at SWAT last month I stopped by their booth and talked to Ken Rizza. He recommended the 600 grit wheel and invited me to see what I thought about the grind using a Tormek-like set up that he had in the booth. To me the results looked a lot like results on the Tormek wheel ... after roughing it up with the coarse side of the stone grader ... not what I wanted.
I told Ken that I wanted to run the wheel in water, but he recommended against doing that. I'll probably do it anyway since I don't like the nuisance of cleaning up the metal dust on my work bench. I understand the concern of corrosion due to dissimilar metals in contact so it will be important to not leave the wheel sitting in water when not in use.
I was leaning towards the 1200 grit wheel, but after more discussion decided to go with a 1000 grit wheel. After getting home I found that getting the old stone off was going to be a challenge. Even though I had updated it with a stainless steel shaft, there was a lot of rust that had frozen the wheel to the shaft. I finally was able to remove the wheel from the shaft after removing them together and using Vice Grips and a dead blow hammer along with a generous soaking of Aero Kroil, WD-40, and whatever else I thought might work. After cleaning up the shaft I saw a lot of pitting which seemed surprising for a shaft that was supposed to be stainless steel.
I ordered a new shaft and bushings, but my progress is temporarily stalled due to back surgery. After I get back up to speed, I'll resume my evaluation.
I have heard other turners say that the Tormek is too slow. As a hobby turner I turn at a leisurely pace, but even so, I don't see much difference in sharpening time between using a dry grinder and the Tormek other than the time it takes to sharpen a skew chisel. Anyway, I found this short Glenn Lucas video showing how slow the Tormek is when sharpening a bowl gouge: https://www.instagram.com/p/BNeh0SjBihY/
