The white Chestnut dye seems very thin and doesn't seem to cover well compared to the green I've used. I'm wondering if anyone has found that to be the case as well or if I got a bad batch?
I think most white dyes will give the same result. As William said - probably best for lightening other colors. I don't know what effect you are looking for, but a few times in the past I just diluted/thinned white acrylic paint and brushed it on - then wiped it off with a paper towel. Sort of gives a bleached wood effect.The white Chestnut dye seems very thin and doesn't seem to cover well compared to the green I've used. I'm wondering if anyone has found that to be the case as well or if I got a bad batch?
Bill, could you please share a photo of an item with that finish?
