Chisels on the cheap
Jackson, MS
I’ve always wanted some mortise chisels and after making a kerfing knife, I thought, why not make some. For less than 20 bucks, I picked up some HSS bar blanks. I had a little 1x1 piece of Lignum Vitae left over from making a mallet so I used it for the center of the handle and surrounded it with Purple Heart. A little beeswax on the handle and now I have a set that matches my mallet so I can whack in style.
Not bad for $10 a chisel.
Was the HSS pre-hardened and tempered? I only ask because, as I think Mark might have wondered, HSS can't be hardened like Carbon tool steel can. If it takes a good edge and keeps it (with a little occasional honing) it's likely been done.
It was hardened when I bought it. I used an angle grinder to shape and took my time to not overheat the steel and finished the angle on a disk sander.
Also HSS blanks the right size were readily available and most importantly, the blanks had square sides and sharp edges instead of rounded edges.
Love the look of these. You truly made magic with your angle grinder. The grind from the handle up to the tool. That transition is really nice.
I made a rudimentary looking pointed scraper like raffan uses. I love it and bought the steel from Amazon. Uxcell I think the company is called. It holds an edge so much better than some of my older hand me down sorby tools. Significantly longer. It's actually quality hss. And I was very new and didn't know about cooling hot steel and bluing it. So, for someone not a novice it would have looked like I was attempting to ruin the temper of the tool. Somehow I didn't. It's hold an edge very very well.
Call me frugal, not cheap. I’m saving for a lathe upgrade.
I used the last 2 HSS blanks I had and made a 3/4” scraper and a 1” shew. Where else can you get 2 chisels for $11 each. Maple for the handles was left over from the bench I made and ferrels were cut from a piece of pipe I had in the junk box.
I didn’t have a straight scraper. The skew I’m retiring I have deemed the spawn of Satan. It’s a 1” oval skew that came with a set of Shop Smith lathe tools and we don’t geehaw at all.
Hahaha. I did the same exact thing. Leftover steel pipe for the ferrule, or I think the scraper has copper. Leftover maple from a table I made for my brother. I make all my own handles with the steel ferrule threaded for grub screws. It's my favorite method. Much easier to sharpen without the handle for my gouges.
Your angle grinder skills are better though.
Someone correct me if I'm wrong, but I think HSS is very tolerant of heating as opposed to high carbon steel.
You can't heat up HSS hot enough with a grinder to damage it. Even if you get it red hot. Carbon steel will turn blue in a heartbeat. That doesn't ruin it but takes the hardness out of that area.
It's funny
I've heard so many conflicting statements but I had come to the same conclusion after reading enough about steel. This is all fairly new to me. I've read countless comments of yours all over this forum dating back a long long time. So I guess I'm just saying I trust your judgement!
Tested the lathe tools out today. They worked great except my shew skills definitely need practice. My daughter wanted a French rolling pin and what a great way to practice.
Skews are amazing once you get the hang.
I recently was lucky enough to get a day of lathe time with Eli Avisera. His cutting edge bevel is only an 1/8 or maybe a hair more. And then the rest is just one continuous bevel rounded to the flat of the tool. I'm not sure exactly how to explain it but I'll take a pic later. I did the same to my skew and it makes a huge difference. Feels much smoother.
I did watch Eli Avisera demo once. His skews have a convex grind, rather than the more traditional hollow grind that comes from the grinder wheel. I do keep one of those handy in my shop. What I find them most useful for is long concave curves. You are rubbing/riding the bevel much closer to the cutting edge than with a traditional grind. I did find this grind to be more difficult to get a long straight surface with than the traditional grind. I would expect that if I practiced a lot more with it, I would be better at long straight lines. Probably the same with traditional hollow grinds....
Much more succinctly put robo.
And I agree. I didn't really think about it but I had the same issue exactly. But I've been practicing with it so slowly getting better. I find I also have less steel touching maybe. It just doesn't seem to burnish the wood quite so much like a skew without that grind. Although I'm very open to the idea that it's a placebo or just my imagination.
