  • Congratulations to Steven Gordon for "Dropped Ice Cream Cone" being selected as Turning of the Week for December 9, 2025 (click here for details)
Chris Natto
St. Augustine, FL
Hey hey! My name is Chris and I’ve been wood turning for about a year. My turning experience has probably been different than most. I’m a C5 Quadriplegic so I have a little movement in my shoulders and biceps, but my hands don’t actually work. After watching hundreds of hours of wood turning on YouTube, I finally decided to sign up for a pen making class at my local Rockler store and now a year later, the obsession has only grown. I came here in search of different tools or techniques that I can adapt for someone in a wheelchair. IMG_0457.jpegIMG_7002.jpegIMG_8205.jpegIMG_7722.jpeg
Hi Chris! I admire your spirit and drive!
I had a good friend, Bruce, who was quad from an accident. His hands didn't work, as you described, no grip or mobility, but he had movement in his arms and shoulders. Like you, didn't let things stop him! He didn't turn wood but was one of the best artists I knew - I have several of his drawings and paintings. We adapted things to help hold brushes and pencils, thins with thin, smooth metal bent to his hand shape. His paintings were amazing - he painted LARGE portraits, painting the lower half first then had someone rotate the canvas so he could paint the top half upside down! Bruce wasn't interested in woodturning but I did make some things for him, including a heavy pencil holder for his desk - if the pencils were splayed out enough he could jam one between two fingers to write and sketch. What an inspiration to me.
In later years he used a stand-up chair, modified a van with a lift. He could drive with the aid of a spinner ball and custom hand/arm controls for accelerator and brakes. I helped him build an elevator for his house but Bruce was fiercely independent and did a lot by himself. He used velcro sometimes!
What are you using now to help hold on to the tools? I'm wondering if custom shaped/carved handles could be made to help keep the tools in position in your hands and make them more secure when using arm movements. I'm trying to imagine how I might hold onto a spindle gouge or hunter tool without gripping with my fingers. Might need to experiment!
Are you a member of a local turning club? If so, someone there may have some ideas for custom handles if you think that might help. (I'm imagining a shaped handle that fit your hand could help keep the cutting edge in the right position, keeping the handle from turning a bit and interfering with the optimum cutting edge presentation.)
What tools do you you the most now? Looks like you might be holding a flat-top carbide tool. I don't use those but I am a huge fan of Hunter carbide tools - in case you're not familiar with them, they use replaceable round dished cutters, secured with a screw, that are incredibly sharp - they can make smoother cuts since they can cut like a spindle gouge, bowl gouge, or a scraper. One great thing is they never need sharpening - the cutters are rotated occasionally to spread the wear around the bit - when one finally gets dull it's easily replaced. I use them a lot, especially certain types. I think used the first one I had for about a year before I had to replace the cutter. I use them on bowls, platters, all kinds of utility turnings, boxes, a variety of spindles. Give me a Hunter Hercules (the small one), a parting tool, a custom point tool, and a few custom negative rake scrapers, and I can turn almost anything.
Welcome Chris. I hope you find the forum useful for you!
To help me hold things I wear these adaptive handcuffs that I glued some Velcro onto. I’ve tried to think of different ways, but Velcro seems to be the safest. In the event of a catch or something, the tool just pops out of my hand, instead of wrenching my wrist in a funky direction.
As for tools I primarily use carbide cutters. I have a small assortment of Easy Wood carbide tools in different sizes and a couple specialty ones like captive ring tools. I’ll have to look into the Hunter tools you mentioned.
I suspect someone who lives in your area uses Hunter tools and would show them in use and let you try them. It's a long walk from here but if I find myself headed that way at some point I'll bring a few.
I do use skews and gouges a lot but I find myself reaching for a Hunter tool often - especially good for very hard woods or those that may tear out easily. To give an idea of what I use it for, here are some recent things, for both the inside and outside of the first one. Persimmon, a type of ebony that grows in the US. I like to turn acrylic with the Hunter also.
I turned this handle mostly with the small Hunter Hercules - this is the surface I got from the first finishing pass after some rough shaping and before smoothing/sanding. African Blackwood,
The small Hercules is the one at the bottom of this picture.
The tool in the middle has a wide flat shaft and an angled cutter and can be used held securely flat on the rest. Simple and effective!
If I'm remembering correctly, I think John Lucas told me he once taught a class of beginners and they used a Hunter tool for everything.
John has great videos, too. Here are a couple but he has more. These show a bit of how the tools work.
View: https://www.youtube.com/watch?v=nfp2kvhH6Mo
View: https://www.youtube.com/watch?v=VgHEou6MlPM
(Disclamer: I have no association with Hunter tools, just a satisfied user. Mike is a great guy, though! You can call him with any questions.)
Hey hey! My name is Chris and I’ve been wood turning for about a year. My turning experience has probably been different than most. I’m a C5 Quadriplegic so I have a little movement in my shoulders and biceps, but my hands don’t actually work. After watching hundreds of hours of wood turning on YouTube, I finally decided to sign up for a pen making class at my local Rockler store and now a year later, the obsession has only grown. I came here in search of different tools or techniques that I can adapt for someone in a wheelchair. View attachment 81102View attachment 81106View attachment 81107View attachment 81108
Welcome Chris! I admire your courage to post about your condition, and share how you turn! It probably takes a lot of effort, but turning is very rewarding, keep it up!
I do use Hunter tools a lot, like @John K Jordan mentioned, call Mike Hunter, he will be glad to talk to you about his tools and which ones would work best for you.
