I'm in the process of building a custom fly rod for my grandson. A rodbuilding site I frequent had a photo of a bamboo rod with a bamboo winding check, that is, the part that makes the transition from the cork grip to the rod blank itself. I decided to give it a try with a piece of caragana like I used for the reel insert. I had a piece that was already turned but was too short, due to being given the wrong dimensions. First, I put it on a mandrel and turned it down with some drywall screen and sandpaper. Next, I put it in the three jaw chuck. When I started to use the parting tool (nervous as it was the first time with this tool), the chuck started to drift out of the headstock. I immediately shut the lathe off as I could envision all kinds of things, none of which would be pretty. I finally put the wood back on the mandrel and carefully cut down as far as I dared with the parting tool and made the final cut with a hacksaw blade (wood was off the mandrel) and did some sanding. Any help for small future turnings would be most helpful. Somehow, I feel obligated for some pictures of the finished rod. Am I right?
