I got the chucker pad from Craft Supplies today. The stem it's mounted on is threaded, the part that goes into the headstock-mounted drill chuck. Just seems odd to tighten up on a threaded rod. No customer service on a weekend. Your thoughts?
Jamie,
I toldja last week or so about the threads. Nobody listens to me. Do they have an emoticon for whining and sniveling?
That is a replacement pad for a dual action air sander, no doubt fits other things too. Go down to the hardware store and ask for a connecting nut, they go by several names but that should get you one. Bring the pad to match the threads. The connecting nut looks like a nut but will be about an inch long. Either glue or locktite it onto the pad threads and you now have a six sided hex shaft to grab.
Hu
Cannot see the mount in the catalog. If You do not want to mar the thread due to possible future purchase of MT with female thread, then you could wrap in tape or make a split mandrel of wood and put over the threads. Oh and one more possible is to put 2 nuts tightened against one another at several places on the thread and place that in the Jacobs.
Did you say something, Hu.![]()
I use Merit Power Lock disk adapters.
Bill.....Where do you purchase your PowerLock discs and adaptors.
I've been getting them at CSUSA and Packard, but wondering if there is a better/cheaper source.....
ko
Jamie,
[Snip]The connecting nut looks like a nut but will be about an inch long. Either glue or locktite it onto the pad threads and you now have a six sided hex shaft to grab.
Hu
