Coring system for REVO 12|16
Berryville, Va
I have a Laguna REVO 12|16 and was recently gifted a beautiful Maple Burl. I would love to get a coring system to not waste 90% of that wood. I believe the Oneway is highly recommended, but the smallest base is for a 14” which means that all turning would need to be done outboard. I have not turned outboard yet, but I am set up to do so. Would the bowl saver Max 3 be a better alternative? I’m not a professional turner but I have turned some Osage Orange bowls and other things. IMG_1265.jpeg
At the risk of an avalanche of proposals for a Oneway or Woodcut system, I’ll hop in and suggest you look for a gently used Mcnaughton bowl saver system. So many people have convinced themselves that they can’t figure out how to use the system safely that there’s a robust market for them used out there. There is information and extensive tutorials on how to use them on YouTube. There’s a learning curve, but if you seriously study what’s out there it’s a very simply system that works well, is very simple and quick to set up and use. The other systems all have a learning curve, too - and a setup that takes often much longer to get done. After a blank is roughed to round and the face is flattened, I can setup the Mcnaughton system in less than two minutes on my lathe and be coring away. The best part is that it’s a small fraction of the cost of the other systems.
I encourage people to take the plunge - find a set either new or used - the standard set will work well for your lathe, go only as fast as your lathe’s horsepower allows (I learned on a Jet 1642 with 1hp). It’s simple and relies mostly on establishing the angle of entry correctly to get the results you expect. Find YouTube content from Robo or Dale Bonertz or Mike Mahoney and choose one to follow scrupulously until you’ve figured out your own approach. And don’t expect to be pulling nested sets of micro thin bowls on your first attempt. I’ve been coring with the Mcnaughton for almost twenty years and the vast majority of what I do is pull two or three cores from what would otherwise wind up in the compost heap or the landfill.
The downside is that you won’t find Hunter carbide tips to use, but then sharpening takes literally seconds…and mostly I just take a few swipes with a cbn hone to refresh an edge.
I would opt for the Woodcut, unless you are brave enough to try to learn the McNaughton. The M3 does have 3 blades so if you end up getting a bigger lathe in the future, you will be set. I do prefer the McNaughton. I do have a 12 inch Oneway some where in the shop, but only for demonstrating. You would need to replace the cutter with the one from Mike Hunter since the Oneway cutters are not very good, at least as far as I am concerned. Most 12 inch lathes do not have enough horse power for coring systems, or at best are kind of minimal in power requirements.
@Harold Rohde , If your first order of business is to core your prized burl, then my suggestion is don't buy any coring system. Instead find a fellow turner around you with some experience who could core it for you. You might even get to try his/her system.
That makes sense - you get the benefit of pulling the cores from a nice piece of wood (you might offer to share with your benefactor) and you get to see a system in practice. I take a little umbrage with the comment “unless you’re brave enough to learn the McNaughton” - if approached with the same amount of care towards safety as most turners use when turning, it’s no more difficult to figure out than the.often-dreaded skew chisel.
Getting to see different systems in use allows comparison of the ease of setup, affordability and flexibility of all the options.
For your lathe you can get a coring system that will work with it. Same three coring systems. Original Woodcut, Oneway and McNaughton. I can't seem to find anyone selling the McNaughton that has them in stock (Lee Valley has them listed but not available for $329). The Woodcut Bowl Saver is available from Woodcut for $508 NZ (about $300 USD) Don't know if anyone here carries them. The Oneway Mini Easy Core system is available from Craft supplies for $304. You have to figure in shipping for all. Consider that you will make more bowls other than the burl you want to core and having a coring system for regular wood will give you a lot of extra bowls and a whole lot less cleanup. Myself in your situation I would jump on the Oneway from Craft Supplies as they have free shipping show up frequently. I have owned all three of the bigger versions of these and have posted why I prefer the Oneway here in another thread.
I know Packard did sell the Woodcut system. I am not sure if they are still in business or not.
Id be happy to let my once-used 12” Oneway system go for $100 + shipping. Might need to get the right insert for your lathe bed, but otherwise its ready to go.
Wow! If I didn't already own the 16" and 20" versions I'd jump on that. Hope Harold takes advantage of that.
