Coronet Major Lathe Universal Machine
Status
Not open for further replies.
Cape Coral ,FL
An iconic machine made in UK (no longer available) I have had this since new (1979) It is based on a wood turning lathe,
but offers... 10 inch table saw, 4 inch jointer/planer thicknesser, 8-inch Disc sander, 6-inch belt sander, Holow chisel, and slot morticer, Headstock swivels 90 degrees for turning large bowls/platters, and for convenient use of the table saw ripping, etc. I believe this to be the only one in the USA. This machine will do a lot of things, but not without setting up for the next operation, so can be a pain (as most multi machines) but if you have limited space, this may be of interest to you.
5-speed "Poly V" drive belts. 120 Volt motor. This lathe has a swing of 9 inches over the bed but swivels 90 degrees to turn up to 24 inches, and it turns in the same direction, so very nice to use. Can only show 4 pics. I am in Cape Coral FL. Please contact me at mrdenniselliott@aol.com
$2.000
Status
