Craig Duncan
Derry, NH
duncansauto.com
It appears I've discovered another rabbit hole to spiral down into.
I've been down many in my life.
I'm retired now so what's one more.
I spent my life in the automotive repair industry, 46 years, being both a mechanic and shop owner.
Specialized in European cars.
I loved the work and - most - of the customers.
Ten years ago I sold the business to my son, who's taken it past my wildest dreams.
You can see it on the web and social media.
Duncansauto.com or on Facebook under Duncans European Automotive, there's a bunch of videos there.
I spent more than a few of the last ten years traveling around this great country shooting black powder cartridge rifles at silhouettes and paper targets, from 200 meters to 1000 yds.
In that game you have to cast your own bullets, load your own ammo and often times, make your own brass.
That was, and still is to a degree a very deep rabbit hole.
Challenging and fun.
I've seen a lot of great places and met a lot of great people doing it.
Spent time rebuilding old Kawasaki 2-stroke street bikes.
Then moved on to Harleys.
The old H2 750's weren't as much fun to ride as they were when I was in my 20's
Modern Harley's are like riding a 120HP recliner, which suits my tastes these days.
So about this new rabbit hole, wood turning.
I guess it started a few years ago when a customer gave me an old Craftsman lathe with a bunch of chisels and other tooling.
It looks like the old "tube lathes" but has a cast iron bed.
I sharpened the chisels with a file, fooled around with a few old pieces of wood and then it sat in the back of my shop here at home, collecting dust and "stuff"
I think it was last winter or early spring I saw a video where a guy poured colored resin around pine cones in a mold and turned a vase.
I thought it looked stunning!
Then I thought, "I bet I can do that"
And I thought my tool and equipment buying days were over when I sold my business.
Silly me.
So I bought some budget carbide tools, built a pressure pot, made some molds ect, ect.
Got a band saw and have been on the hunt for a decent used lathe or a new one that's not in the Powermatic class.
I know, I know, bleed once, but I'm not going to bleed that much quite yet.
After a few casting failures and a couple of "unexpected rapid departures" of work from the lathe, I finally turned a somewhat acceptable looking pine cone and resin vase.
I'm not going to buy tooling for, or put any $$$ into that old Craftsman lathe, though I did replace the headstock bearings.
It serving it's purpose of letting me learn techniques for now.
When I find a replacement, I'll pay it forward and give it away.
I enjoy reading the posts here and seeing the work you guys do.
There's a wealth of info here.
"Once you stop learning, you start dying" - Albert Einstein
Thanks for letting me join,
Craig
Craig, Welcome to the forum! You've had an interesting life. Woodturning will certainly add to it. I checked the shop's website and that's some operation there.
Mark
I've been reading a lot here on the forums and, using the search feature to answer questions I have.
The search feature here, for some reason, works much better than other forums I participate in.
I've been looking for a lathe and may have found a used one locally.
It's a 2018 Jet JWL1642evs.
I comes with a host of tooling, face plates, chucks and more importantly, spare parts.
Like a couple of spare belts and 2 NIB VDF controllers.
It's the 110v version.
I've read here about the problems some folks have had with electronics and replacement parts.
Asking price is $1200.
I'll check it out in a couple of days when we get back home from vacation.
Hope it looks and works as good as the online listing seems to show.
If so, it should be a good quality tool to learn on.
Thanks for the Welcome,
Craig
Craig
Craig, that Jet 1642 was my first lathe and served me very well for years with no issues. I only sold it because, due to multiple surgeries and hospital stays, I didn't think I'd ever get back in the shop. I sold off a bunch of tools then also.
But I'd give it a good look to be sure there are no issues with it now, and I'll bet you'll be pleased with it for a long time.
Yes, try it out - it's a great model. I've had two of the 110v versions. Plenty enough power for what I like to turn.
Pretty easy to move too. I've moved and set up both by myself, then took one apart and set it up at a friend's house.
Something that kills lathe VFDs is power surges and lightning strikes. A good industrial surge protector will help. Unplugging the lathe when leaving the shop will help more.
I picked up my 'new to me' lathe last night.
Spent the day giving it some love and putting it back together.
Someone had painted the ways at some point in it's life so I spent the time to sand it all off.
Went all the way up to 1000 grit and now they shine.
I waxed them with a "gun wax" I make from beeswax.
It's used primarily on white steel to prevent rust.
Took the tail stock, head stock and tool rest apart to clean and wax all the moving moving parts and surfaces that ride on the bed.
Now I can slide the tool rest and tail stock with one finger.
I used grade 8 bolts to hold the bed to the legs rather than the socket head cap bolts that came with it.
It didn't like the GFI circuits I have in my garage so I made one wall circuit non GFI, it works fine now.
Funny, the GFI's never bothered my old South Bend metal lathe or the Craftsman wood lathe.
I figure it had something to do with the VDF inverter.
The whole shop is protected by a 200 amp surge protector as I have some expensive scales and powder dispensers for my reloading equipment.
It came with an 8 piece Sorby set, 3 home made carbide tools, a Nova G2 chuck set, a few tool rests, a few face plates, a duplicator attachment, a few live centers, a Jacobs chuck, 2 spare VDF/inverter units and assorted calipers and protractors.
You can see all the stuff in the photos.
Oh and a couple of big Maple burls that are still in my truck.
I'm happy with it and feel the $1200.00 was well spent.
Now I need to learn how to use it. :cool:
Hope everyone has a great Labor day Weekend.
Craig
Craig
View attachment 79024View attachment 79025
What a deal!! Congrats on your new lathe
Great! Now the fun starts!
All 1642s I know of tripped GFCIs, including mine. Did some rewiring. The used PM I bought later used 220v so I did more rewiring. (Nice reason to panel shop walls with plywood fastened with screws!)
A tool manufacturer in Europe recommended rubbing talc (as in billards talc) into cast iron to fill the tiny pores and keep it in good condition. I've been doing that on a table saw slider attachment since I got it but haven't needed it on the lathes. If the tailstock gets harder to slide I use a scraper and steel wool to get off any finish and rub on a coat of Reniassance wax. Never had any rust.
BTW, did you check the bed alignment? I had to align both of mine and also one at our club in the middle of a Mark StLeger demo. It's not that those lathes have a problem, but any cast iron bed can easily twist if the four feet lets are the least bit off a perfect plane. If you haven't heard how: put a pointed center in the headstock and tailstock. Slide the tailstock up so the points are almost touching. They should align both when looking from the top and from the side.
If one point is a little off when viewed from above, the fix is easy: just raise one foot a tiny bit. With leveling feet just turn the nut a bit, otherwise might need a shim. For example if the tailstock point is a bit off towards you, raise either the front right leg or the back left leg a bit. I check that everytime I move a lathe in case the floor is off a bit in a spot. A bit of misalignment may not hurt when turning some things but can be a real problem for others.
Osie's photo in post #52 of this thread shows the proper alignment from the side.
https://www.aawforum.org/community/...he-a-new-lathe-is-now-on-the-way.24439/page-2
