Current motor and electric bill
Colebrook NH
ebay.com
I've been running my old Craftsman lathe for a month now and just got my first electric bill. OMG! The motor is an older 1/3 hp 1750 rpm 120 volt. Is there the possibility of buying a new motor, maybe 3/4 hp, that will drop my power usage to an affordable level?
Where I am the answer would be to go from 240v single phase to 220v three phase via a VFD they are not expensive and this will allow for electronic variable speed via frequency control.
But keep in mind, low frequency low torque. So what I do is to keep the stepped pulley set up and put the belt on the slowest speed . This then gives you more troque low down and you should be ok.
At most, under full load constantly, that would draw under 500 watts. 12kwhrs a day, or about two dollars at typical rates, if run hard 24/7, which would burn it up in short order.
In reality, it's extremely unlikely that the lathe contributed more than a dollar to your bill.
All right, guess I'll look elsewhere for the energy drain. I heat my house exclusively with firewood so I know it's not the heater. Thank you for the info.
There are lights, removing incandeescent light can save a lot. I have LED through out probably the equvalent to couple 100 watt bulbs. We have three bedrooms, two bath , open plan living , plus me in the garage. There some health consideration with going to LED's othe than that they are more cost effective.
I have LED s everywhere but the garage. I still use tube fluorescents out there but they get used whether I'm turning or not. Occasionally I'll forget to turn one off but that's rare
Look and see if your rate per kWH has gone up a bunch-- it certainly has across the border in MA. Also see whether the number of kWH used has changed significantly. To sort out all the fluff they put into your bill these days just take the monthly total and divide by the total number of kWh for the month to get the actual rate you're paying for your usage level.
With typical rates running 30-35 cents/kWH in this part of the world even a couple extra kWH per day can add up to $20-50/month very easily. It's making investing in solar panels look like a better deal every day-- we added to our system two years ago so that our bill now averages very close to zero for the year. One of my less foolish choices in terms of return on investment.
I'll do that. Thanks for the tips.
Search for power monitor. Many are available; some will monitor multiple circuits at the same time. Also, might ask the utility company for ideas.
Just a thought out of left field: you are in New Hampshire and at the beginning of the heating season. Do you heat with electricity? Could just be a coincidence that you started turning recently.
No, I heat with firewood. I've lived here for 20 years and have never turned on the heaters. Thank you for the thought though.
I'd recommend getting or borrowing a device call "Kill A Watt" . This plugs in to the wall, and in turn you plug in your device to it, and it will tell you how much power something is using. Truly an eye opener. I was not aware of just how much power many devices use even when "off". Anything with a clock, for example, will pull power - Stove, TV, Computer etc. These parasitic drains can add up significantly.
I have a couple of larger aquariums, and we were always worried about the power consumption. I did some research, and learned about DC pumps. Using the Kill A Watt, I could verify the reduction in electric consumption of over 50% by converting to DC pumps from AC.
I'll look into it, thank you all for your input.
A 1/3 HP motor at full load draws about 7.2 amps on 115 volt and a 3/4 HP motor at full load draws about 13.8 amps on 115 volt, these ratings were taken from a National Electric Code 1996. The wattage equivalent of 1HP is 746 watts plus a little more for the inefficiency use the figure 800 watts so 1/3rd of 800 = 267 watts or 3.75 hours to use 1 KWH and 3/4 of 800 = 600 watts or 1 2/3 hours to use 1 KWH. The bottom line is the larger motor will cost more to run so check your records to see what your past KWH rate was verses the current rate.
Our electric bill (across the state in Durham) has gone *way* up this year.
Be happy—I’m in California where rates skyrocket yearly. I went solar and had no bill and they just changed the rates so everyone has at least a $27 monthly bill regardless of how much energy they give the grid. We get paid 1 cent per kWh and are charged 37 cents. I gave them almost 2 mW last year. My wife calls all the taxes—don’t get me going about gasoline—sunshine taxes.
But you get such great safety and customer service from PG&E! Seriously, talk with your state legislator (speak in person!) about that reimbursement rate; they ought to at least pay the wholesale generation price.
If you’re connected to the grid though a monthly fee is completely reasonable, transmission infrastructure is not cheap, so if you use it it’s fair that you should pay for it. (here transmission costs are higher than generation costs per kWH). The alternative is a pretty expensive battery package and perhaps generator to go off grid.
We get paid zip for the electricity we generate and give to the electric company. Nada. Zilch. Nuthin.
