A search showed no matches, so here goes. Have any of y'all tried to turna dakota burl? I bought two seveal yeas ago and just never got around to turning them. Recently a relatively new turner friend of mine, showed me a couple that he tried to turn. He asked me what he was doing wrong. I told him that it looked like he was scraping and using dull tools. He gave me the other 5 pen blanks that he had. I more closely inspected the torn and voided chip outs on his attempts and discovered that the crushed sunflower hulls did not appear to be glued together well. I took the blanks and chose one, laid it on its side on a plastic grocery bag, and thouroughly soaked it with thin ca glue. I soaked it several times ofer a two hour period until it would no longer take any more glue. Then I turned it over and soaked it from the other side. The second side did not appear to take very much glue. Two days later I cut the blank to length, drilled it and soaked the inside hole with thin ca. I filed the inside smooth to take the brass tube, glued it trimmed the ends and turned it using a freshly sharpened 3/4 roughing gouge, then switched to a very sharp skew. Nearing the final diameter and getting close to the bushings, a little chip out became noticable. I marked everything, removed the blanks and soaked the blanks, especially the ends in thin ca and filled the chip out. It seems to me that this is a very costly process in time and material, mostly ca glue. Did we get a bad batch or is this stuff just not worth the trouble? It does not look that good anyway. To me, there are a lot of other materials, including wood that turn so much better and look so much better. Any suggestions or comments would be appreciated, Thanks!
