Deciding between Harvey T60 and Record Power Regent Lathe
Punxsutawney, PA
I’m just about ready to buy a bigger lathe. I have the choices down to the Harvey T60 and the Record Power Regent. It seems Record Power might have better customer service. I’ve emailed Harvey and have not gotten a response but the Harvey fit and finish does seem better. I was thinking of going to the symposium and maybe getting to see them if they are going to be there. Any suggestions or real life experience would be a great help.
Thanks
Brian
I'm curious what criteria you are using. They seem to me to be in entirely different classes. The Harvey has a 24" swing over the bed, 48" between centers, a 3 hp motor and weighs over 700 # while the Record has an 18" swing, 24" centers, 2hp motor and weighs a bit over 300 #. A couple of minuses on the Record to my eye are the 250 rpm minimum speed and the lightly built tailstock. I can't speak to customer service.
Rotating head is really important. I would buy the extension for the Record. I have reservations about the 250 speed
The Record Power seems like a really well designed lathe to me.....but the overall weight is what I can't go along with. I agree about the rotating head......IMHO, that's a much better option than a sliding head. No need to mess with the tailstock, and change your body position for turning.
For me, I could get by with 250rpm. I seldom need slower than that, but those times I do use a slower speed, it's handy to have.
I just had a friend upgrade. I looked at a lot of lathes for him and thought the Harvey looked like a good deal. He decided to go that route. He wont get it until July. I did not include the Record lathe because I didn't see any ads for it on my searches. My friend and I live in Tennessee USA. Marbe the Record isnt sold over here.
Significant size and cost difference between those 2 choices. I would not consider them as comparable. Compare the Regent to the Nova Orion (18" swing), or perhaps the Galaxi (16" swing). I mention the Galaxi because the outrigger fits and works. I'm not sure Nova has an outrigger that fits the Orion.
Don't believe the HS on the T-60 pivots (T-40 does). Need to look at Laguna, Powermatic, Oneway, Robust for 24" swing comparables. Grizzly has a 22" swing(G0766).
I did look at Nova lathes but I’ve heard the service is pretty bad. Oneway and robust are great except for the price. I want either a rotating head or a sliding head.
Brian...first off, let me share my experience. I've been turning since 2006. I've turned and demoed on numerous makes, including the high end lathes. At least 15 Powermatic 3520bs, a Robust American Beauty, several Jet lathes, a Serious SL2542, etc. I have the G0800 Grizzly, which is the same lathe as the Harvey Turbo-60, which was made by Harvey for Grizzly before they decided to keep that frame exclusively to market for themselves. The only difference is they went to a D/C 2 hp motor with controller, which is industrial duty, and my lathe has an A/C 3 hp motor with inverter.
The Harvey T-60 is a highly precision machine. The ways are highly polished, and the lathe is a heavy duty beast with a nice swing away tailstock, sliding headstock unit. My centers lined up to a precision degree, and the tailstock quill has ACME threads, which are hardened. The spindle lock is much better in my opinion than the ones on PM 3520 lathes. The belt is a special made for high torque applications, which is needed for low speed turning of heavy wood.
When I decided to get my Grizzly version, I was almost ready to pull the trigger on a Robust American Beauty, but after doing deep dives in research and looking at the build, I went ahead a got the G0800, Harvey T-60 clone. I could not be happier with my purchase. I have not had a single issue, not one, after 4 years! That lathe is as nice to turn on as any Oneway 2436, Robust, or others I have turned on. I turn some big heavy wood at times, and my lathe has handled it very well. The bearings on the spindle are all bigger than a baseball! The precision machining on this lathe shows up in how smooth and quiet it operates.
When I relocate and get my bigger shop built, I may still get a Robust American Beauty, because I really like that lathe, but I'm keeping my Harvey cloned G0800, as it is every bit as much a pleasure to turn on as the Robust AB. It is truly a premium turning platform. I also have the bed extension for it, and can turn off the end with the headstock moved to the end, and the swingaway engaged. The banjo riser can be ordered to use with the bed extension. All lock up solidly, and are heavy duty.
Good luck with your decision. BTW, I have spoken with Harvey reps over the phone, and they stand by their machines. I don't know how things have developed over the course of the pandemic, with supply chain issues, but my experience has been all positive.....John Hicks has the Turbo-60, and reports from him are all positive from what I've read.
Don’t know if you bought yet. I would recommend the Record power Envoy Or larger one. I bought the Envoy. I have had it about a year and love it. Their customer service is excellent. I have not needed it but a few people had a problem with the controller so they sent a new one to everybody for free. a couple of people had a problem with the hold down bolt so they sent a new one to everybody with a free Chuck for the trouble. Now I have a spare controller, hold down bolt and free Chuck. The reason I went with the Record Power was the rotating headstock and the pendant with all of the controls.
F50B4848-6618-4685-BBC8-1F845DD5DD77.jpeg205847DA-9F1E-4D81-B110-37A79AB74F93.jpeg602184DC-DE33-4BD8-A911-C530C690C9C4.jpeg
Good for you Greg! Glad the RP is working out.
I've had a RP Herald for about 2 years now and like it a lot. I usually keep it in the middle belt position, 140-1800 rpm, and have not used the 'swing' yet. My only nit picks are it takes about 5 seconds for reverse to 'kick in', which doesn't seem like much but if you're doing it 10 or more times in an hour it adds up! And, it takes about 4 or 5 seconds for the lathe to stop spinning, which really adds up over an hour. Does your version work that way, too? Minor things that I'm used to now.
Tom
