Delta wood lathe chuck
Indian River, FL
IMG_9622.JPGI have an old 12" HD Delta lathe. Looking to turn thumbscrews and saw bolts. I've never used a metal lathe and can't quite figure out how the backplates and threaded hub parts work out. Was thinking a small 3-5" 3 jaw self centering, cheap 1-8TPI chuck would work perfect. I can't find many backplates that have 1-8TPI? Is It better to use MT2 adaptor for a metal chuck?
Figured some of you guys must turn some brass or at least how to best mount a chuck.
I have a Oneway chuck and the lathe has very little runout. As soon as I touch a small piece of brass I pushes it off center. Guessing either the chuck or the jaws doesn't have the grip to hold a piece of round stock like that. If I can work out the best mounting option then Maybe I'll looking into a cross slide or tool holder.
Thanks for the help
Timothy Allen
Maine
Try removing the wood turning jaws from your chuck and holding your brass just with the base jaws (metal-working chucks don't typically come with front-mounted jaws like wood-turning chucks do). Another approach would be to get Oneway's #1 step jaws (#2156 for the Talon and original Oneway chuck) -- designed for holding small pieces like that (I've used them turning 1/2" aluminum rods on my lathe). Third approach might be to invest in a collet chuck like from Beall
Indian River, FL
I will try removing the jaws. I really like the collect chuck idea, I only use 2 sizes of brass. I know there are a few different types, Is Beall my only option?
Considering all the different metal lathe back plates, I imagine a collet chuck other then Beall would be difficult to mount.
What about an ER32 collet chuck? comes with the chuck and 11 collets for $67. Guess I'll have to do some research on this.
Now if I can get a knurling tool working on this. Wonder if that puts a lot of pressure on the spindle and bearings?
Timothy Allen
Maine
The Beall collet chuck IS an ER32 collet chuck, designed to mount to a wood-turning lathe spindle (available in the common spindle threads). Not sure about the one you've found -- will it mount to your lathe spindle?
Indian River, FL
I noticed the Beall chuck is er32 also after posting. I searched ebay for er32 MT2,guess these are morse taper.
Which is better? Guess you'd have to use a drawbar with MT2.
Maybe a Beall 1-8TPI chuck and a set of cheap collets
Think I'll go psi chuck and a set of ebay metric collets.
