Digital Calipers?
Portland, OR
My Fellow Geniuses,
I need to pick up a nice set of digital calipers that I see a lot of dudes using on YouTube. The brand I see the most is Mitutoyo. Now what type of calipers by name, I dont know what they are called. I know what they look like but that would be like me describing a duck. Any advice and numbers sure would be helpful. The numbers I wrote down are 500-196-30. That is the style I am looking for. Not real expensive. I am a really lousy turner but I am getting better and I LOVE buying tools. Thank You Much!
Thom Schuck
Portland, Oregon
Hi Thom, I think your choices end up being in price range of Mitutoyo and up, and what can be found in the +/- $20 range at local hardware stores and outlets like Harbor Freight. My local home center chain (Menards) has 3 digital calipers available from $5.00 to under $20. Until you approach the "expensive" end of the price range, you'll find most of these tools come from China.
For my woodworking purposes, the Harbor Freight digital caliper has been fine. They'll all usually toggle between metric and imperial (displayed both in fractional and decimal). And they can "zero out" for accuracy. But they also tend to burn through batteries, maybe annually with casual use.
Not to dissuade you from digital, but @John K Jordan pointed me to these fractional dial calipers and I love them, and no batteries!
Thom the trouble with most of the cheap verniers is that they use hearing aid batteries which do not last very long. the Kynup Digital Caliper on Amazon is stainless steel, takes much bigger batteries (comes with 2), has auto shut off and I've had the same battery in it for over two years. $19.99.
My experience with the cheap digital ones is similar to Bill's. Seems that every time I needed it, the battery was dead. Even off, it seemed to drain far quicker than reasonable. For this reason, a month ago purchased an analog caliper. So far, so good. Plenty of precision and it is easy to read etc.
I also prefer an analog caliper for turning. But at some point I purchased Wixey digital calipers from my local Woodcraft. Works just fine.
With my elertronic devices that use button batteries I leave the battery "drawer" partly open when not in use (interupting the circuit), and this greatly improves battery life.
My Fellow Geniuses,
Thom Schuck
Portland, Oregon
Go with this option. It is very reliable and has a large screen. Our last set lasted 4 years.
I run several digital vernier calipers Mitutoyo, 160mm and 300mm. But for any general wood lathe I use a digital plastic body, as wood dust doesn't really improve them and the Mitutoyo aint that cheap down here
I have a couple of them in my shop. I just went to the big box store and got some. They handle metric, standard, tenths, and fractions. I can't read the dial type ones any more.... Ace Hardware here in Eugene, Jerry's.
A few of my herd.
The bottom plastic one gets used often on rough, dirty work. The next one up was liberated from a WW-2 bomber factory in occupied Japan. It is imperial on one side and metric on the other side and has vernier scales. Imagine an 80-year-old caliper that can convert from imperial to metric so easily. Very accurate and smooth, but hard to read. Other than the hard to read, I love using it, and it's not bothered by dust. Next is a cheap, no-name Chinese dial caliper that I bought 20 years ago. It is my most used since I'm not afraid of ruining it. It has some kind of gunk in the track and will only open to 4" or so. Than a variety of expensive name-brand calipers. All about the same and seldom, if ever, used. The top is a digital Mitutoyo, which measures to .0001, and it's the most accurate. I've had it 5 years and still on the original battery. It gets used in metalworking because of its high precision. It will measure really close to a quality micrometer.
I won't allow any of the cheap digital calipers in the shop as they go through batteries so fast and some are not accurate.
If I had to choose, I would keep the Japanese slide caliper and the cheap Chinese dial caliper. Glad I don't have to make a choice.
Based on seeing a couple recommendations, I bought an iGaging brand of digital calipers, after several cheap ones proved to be, well, cheap. It's tolerably priced. The iGaging is clearly a notch up in build quality, and the battery seems to be lasting longer. It also came with 2 batteries. That said, unless I need digital fractions or metric, I use a medium priced dial caliper.
igaging calipers
I use nothing but fractional dial calipers. Saves a lot on batteries.
I've had Brown & Sharpe, Starrett, and now a Mitutoyo. The B&S and the Starrett both failed within 3-4 years. I contacted Starrett about repair on their model and was told it was obsolete and no longer repairable. they offered to sell me the new version for something like 1/2 price of new. Instead I bought the Mitutoyo off ebay, no idea how old it was, but I've been using it for over 8 years now and it still works. I have to admit, the dial calipers are very useful and just as good for most uses.
If you want the best....
I have at least 5 Brown & Sharpe dial calipers. Swiss made about 200 bucks. The nicest feature is they don't have the thumb wheel which I hate. Number 599-579-4.
Several posters mentioned verniers, no, you don't want those.
Also I see the somewhat idiotic use of calipers to mark spinning blanks on the lathe in demos. Not a good thing to do.
Had a few digitals in the machine shop, the expensive ones, Mitutoyo, Brown & Sharpe, etc. Users preferred the dial B & S's. The digitals quit working if they get liquid on them, even those with a liquid proof rating. We put those in a drawer and found after a few years they worked again with a new battery.
I read an interesting analysis of various digital calipers some time back by an electrical engineer. The summary was that the cheap calipers have terrible power management, while specifically Mitutoyo "does it right". Some of the bad ones not only have much higher power draw, they don't really turn "off" properly and continue drawing significant power when off and not in use. I have two Mitutoyo calipers which I use very regularly, and they last forever on a battery despite using vanilla SR44 (silver oxide) hearing aid style batteries. You can use LR44s (the alkaline version), but should prefer SR44s per Mitutoyo's recommendation – they have very little voltage drop over the battery's life vs alkaline, which works better in the calipers, particularly as the battery ages.
My vote is the $1.49 plastic calipers show above. Just don’t use it while the work is turning. Lots of accuracy for wood turning. I bought battery digitals long time ago and can never use them because the batteries are usually dead. Usually fitting two pieces together and need a glue gap anyway or when it fits it fits and measurement is quick way to a close fit.
My favorites are Mitutoyo and Starrett, used mostly when machining. For other digital measurement things I take the batteries out when not in use. But as mentioned before, I really prefer the mechanical dial calipers, both metric and imperial, over digital. I rarely need to measure things to four digits after the decimal point. And I've learned to dislike digital calipers that pop up the fractional equivilant when "close".
Fortunately, for woodturning exact number are rarely needed - good mechanical dividers can precisely transfer most dimensions without measuring. And when turning spindles, if I want consistency in sizing diameters I go with the cheap verniers - never read the scale, just set them to copy an existng diameter or to whatever looks right. Bought a bunch from Amazon once for $4 each. (Round the corners as in the top one.)
One thing I'd hate to be without is a good dial indicator on an adjustable mount, mostly to check for conentricity on chucks and to get things aligned to suit me, for example jam fitting this double 3-corner bowl from cubes. (And if looking for a good dial indicator mount, nothing beats the single-knob Noga. But the clones are still pretty good and 1/4 of the price.)
cheap calipers have terrible power management, .... Some of the bad ones not only have much higher power draw, they don't really turn "off" properly and continue drawing significant power when off and not in use.
I've heard the same regarding small, inexpensive electronics in general. Hence I "remove" the battery when I'm not going to use it for a while.
I've been using the same Mititoyo digital caliper for over 35 years. The cheap ones are equally accurate but tend to eat batteries. I replace the batteries on mine every 2 or 3 years. I don't feature taking the battery out at every use.
Dial calipers are fine but the rack and pinion tend to clog with dust in a woodshop, so keep them in a drawer or case. With digital calipers it is easy to zero out at any opening and obtain a differential measurement without arithmetic.
The model you are looking at is a good basic model but beware of cheap lookalike knockoffs. If you pay less than $130 or so it's probably made in China. I don't believe Mitutoyo makes a fractional readout model, if that's important to you.
Biggest battery problem I have is remembering to turn it off when I am done.... I think some of them have a "smart" feature so if it is not actively being used, it turns off all by itself....
I finally hit the jackpot last year with Kynup, here. Before that, I constantly ran into issues with replacement batteries not actually fitting a young but battery-dead caliper. These also feel much more solid that the others, move smoothly and lock easily. Replacement batteries actually fit!:cool:
First @John K Jordan, and now @Jamie Straw. Who else is going to cause me to buy another new caliper? (This forum is expensive!)
Thanks for posting those, Jamie. I may consider adding a set of those along with John's excellent 1/64" fractional dial calipers.
