Do you clean your CBN wheels
Yes, Ken Rizza (when he owned Woodturners Wonders) said to use WD40 and a steel brush.
William, have you used them for metals other than hardened tool steels (such as turning tools)?
I think what I've read so far is what I've read before. I think @robo hippy has explained cleaning after grinding softer metals, so a quick search referencing him may help. I bet he'll chime in here at some point.
I have only sharpened HSS and harden steels with CBN wheels. However I am sure some wood does get imbedded into the wheel even though I try to remove it before sharpening.
The only thing I found was where Robo Hippy said There was an aluminum oxide block available, but again messy.
I clean my saw blades by soaking in a hot soapy solution (I use Dawn) for about an hour and then a quick scrub with a nylon brush and then rinse, dry, and oil.
Would that work for CBN wheels?
Maybe some day, if I remember, I will do a video on CBN wheels since my old web site is not gone.... Dave Schweitzer of D Way tools told me he soaked his wheels in Simple Green and then hit them with a scrub brush. I have heard a number of times that using glass cleaners is not good for the wheels and your lapping plates, and probably the paddles, if the cleaner has ammonia in it because that can bother the nickel plating that keeps the CBN on the wheels. I do have automotive cleaners in the shop for this purpose, and use them on my lapping plates. I do have one 320 grit wheel that has a bit of imbedded metal in it and can hear it "ticking" as I sharpen. I have tried the old aluminum oxide grinding wheel, and it didn't get that piece of metal off the wheel. Oh, I have looked for it and can't see it with my eyes, but that may be me, and I have not looked really closely. I do have some hard aluminum oxide around some where, if I can find it. The AlO does make a LOT of dust. I have heard of using those rubber eraser sticks which I use on my abrasive discs to clean them up a little, and they can be used to clean up the lapping plates. I do generally apply a bit of the Trend lapping fluid to the bevels of my tools before sharpening. Wet madrone leaves a LOT of residue on every thing as I turn. Most of the time, other than the lapping fluid, I don't worry about it as long as the edge looks to be refreshed.
I use a slurry of Barkeepers Friend to clean my water stones and diamond stones. Haven’t seen a need to clean my CBN wheels yet but I imagine that would work on them also. I’m sure it would be messy too but wouldn’t want to remove the wheels to clean them.
If so how? I have used WD 40 with a steel brush and also used Windex to clean. Is there a better way?
Hello William! I soak mine in Easy Oven Off. I also use it to clean the chains of my chainsaws. Soak overnight for better results.
I don't think I've ever cleaned mine. Before sharpening I usually dribble a bit of diamond honing/lapping fluid such as "Trend" on the wheel, turn it by hand and spread it evenly around the wheel. After sharpening, wipe with a piece of paper towel. The paper towel is black and the wheel is cleaned of the HSS steel particles. Clean enough for me.
However, the wheels I use are 1000 and 1200 grit CBN, pretty smooth. I haven't tried or needed this with my quite coarse 60 grit CBN I use for shaping tools, or other intermediate grits.
A little lasts a LONG time. I've been using the same bottle for years.
Maybe I'm doing it wrong. I've never cleaned my cbn wheels and they seem to work just fine. I spray water on the diamond plates to float off the swarf and wipe them with a dry cloth when done
I just used a 180 grit DWay v wheel for close to 10.years. I definitely abused it grinding carbide and after I got tge dlick stick I ground carbon steel tools. I did clean it about a year ago using ken Rizza,s method. It looked better but I could not tell it changed the cutting action at all.
I cleaned mine once with wd40 and a brush, but didn't notice any difference. I would be sure to read the label on any chemicals you may use if cleaning aluminum cbn wheels. Some of the oven cleaners have caustic in them and will dissolve aluminum.
If I only turned dry wood, I can see that I would never need to clean my CBN wheels. However, constantly turning sloppy wet wood makes it a necessity some times.
I did grind some carbide on my CBN wheels once. I notices a significant drop in grinding ability right after. Diamond works better as far as I am concerned. I do have diamond wheels or my Tormek, and some day, I will mount them. The local Woodcraft store just closed and they had a sale, so I bought another one. It was on sale.....
In other words if you took 30 seconds to use a brass brush to remove the gunk from the tool, you'd never have to clean your wheels. Now I get it, but I still can't figure out why brushing the tool is too big of task for some.
Soak mine in cental heating oil or diesel overnight then use a brass brush. Certainly lots of black grinding dust in the mix so must be unclogging/cleaning. Is it any better afterwards, hmm, jury is out on that one.
I've had one of my CBN wheels for at least 15 years and the other on the same grinder for at least 12 years. They have not nor do they need to be cleaned. The only steel that has ever touched them are 10V tools and once a 15V tool. The 80 grit on the right side did touch copper once when the 220 cord to my lathe (due to inattention) touched the spinning wheel. The loud bang and spark were somewhat distracting. It left a burn mark on the CBN wheel and the grinder is a tad louder. If it ever gets worse I'll change the bearings🤪
... The 80 grit on the right side did touch copper once when the 220 cord to my lathe (due to inattention) touched the spinning wheel. The loud bang and spark were somewhat distracting. It left a burn mark on the CBN wheel and the grinder is a tad louder. If it ever gets worse I'll change the bearings🤪
Ha! I've never thought of experimenting by grinding a hot power cord! :)
If soft materials clog up the wheel, wouldn't the brass brush also do that?
The oil loosens the particles and the brush just dislodges them and cleans it up. I suppose you could use a hard toothbrush if you wanted to. I take the wheel off, soak it in a suitable size tub overnight, and then clean it with a small brass brush I had for cleaning suede shoes (remember them!). Takes about 10 minutes and you're good to go. I don't, or indeed, wouldn't do it with the wheel spinning, so there are no issues. Hope that helps.
I remember Dave Schweitzer commenting that he would soak his wheels in Simple Green, then hit them with a brush after a couple of hours. I have also heard that ammonia can bother the bonding of the boron particles. Not sure which to believe. I do have some very hard aluminum oxide bits around the shop that the Burton Saw people used to true up my first CBN wheels. It does make a dusty mess....
Woodturners Wonders used to sell a product called Slick Stick which they recommended for cleaning. Videos online show it working well on CBN wheels. I have used it on my Tormek diamond wheels but never had the need to use it on the CBN wheels.
I thought Slick Stick clogged my wheels. Ken said I was using way too much. So I cut way back and now haven't found the need to clean the wheels. I do clean the tools first if turning green wood.
Someone above mentioned using some kind of Aluminum product to clean CBN wheels but the instructions that came with my wheel said to not use the wheel on any soft metals such as Aluminum, Brass, and similar. It said any soft un-hardened steel could also tend to clog the wheel. I keep a small steel wire brush near my sharpening station to clean debris off of the tools before I sharpen, and have yet to see any clogging. My sanding discs are a different subject... I clog those up all the time. Those rubbery eraser bar thingies (sorry for the technical term) work great until I burnish the dust to into the grit by pushing too hard with the sandpaper. I suspect if your CBN wheel has a very minor rub of material, those eraser bar thingies would work easily.
I don't have much faith in those rubber sticks for CBN. Maybe as you say if something light got on them. For me a little PB Blaster and a wire or brass brush to scrub the wheel does the trick for me. If you get brass or aluminum embedded in the wheel, that is a different story. Take a good high speed drill bit, hold it in vice grips, set the tool platform at 90 degrees, start the grinder and put that drill bit into the wheel hard so the grinder almost gets bogged down and let that drill "dig" out the brass or aluminum.
Most people won't need to get to agressive when cleaning their wheels. Here are things that happen than might require cleaning:
1.) not cleaning tree sap off your tools before sharpeninng
2.) consistent grinding of softer metals, iron, brass, aluminum
3.) someone else who is uninformed about such wheels and they use your grinder for God only knows!
I had an old set of almost worn out CBN wheels, D Way, and intentionally loaded them up with brass, copper, aluminum, and mild steel. I then sharpened as normal. After a month or two, there was NO visible marks on the wheel of the soft metals. I don't think I had many V10 or M42 tools at that time, but I did have the Big Ugly tool. I do have one wheel, and I can hear a "ticking" noise when I sharpen some times. That generally means there is loaded/soft metal on the wheel. I can't see it at all, and have tried aluminum oxide from an old wheel that I would not give to some one I didn't like, and it still seems to be on the wheel. Oh well, it still sharpens fine. I do get gunk on my wheels when I am turning fresh wet madrone, and it is very sticky. Most of the time, I don't bother with cleaning off the tools before I sharpen. I do make a point of wiping off the tool before going back to turning. Any metal dust will leave finger prints, and spots all over the wood.
