I'm sure this had been discussed but just got through finishing a small bowl that had a tenon during the process. What determines a tenon or dovetail for turning a bowl? Thanks.
The other place I use a recess is while coring; I use a tenon to hold the log during coring, but I'll make a recess in the front side so that after I've made the biggest bowl I have a way to hold the core to make a tenon on its back side for the next round of coring. That way all my cored bowls have a tenon for re-mounting when they have dried and I don't waste wood.
It probably doesn't make a ton of difference if you are able to dish the piece in within the diameter of the smaller bowl and make an inset tenon. If you don't do that you lose 1/4 to 1/2" of depth on all of your bowls. That may or may not matter to you. The recess just seemed easier to me. I only use it for a minute, forming the next tenon at small diameter. I also bring up the tailstock for most of that cutting, pulling it away just to take off the final nub (then hoping to remember to bring it back to mark the center for later!).Roger, what's the advantage of a recess instead of tenon in this case? Easier to cut? Less diameter lost for the smallest core? I've always used a tenon on the front side, but that's from force of habit since it's what I use elsewhere.
. What is your approach to turning down the tenon just before completing the turning?
.thanks to all. BTW, does anyone have or recommend a video for the proper way to remove a tenon?
I am also a tenon fan. Mostly because it leave so many options when I reverse turn the bowl. I can make the foot any size I want or no foot at all. I can turn a rebate (as long as I calculated that into the design while hollowing). I do use rebates on most of my platters. Even then I may reverse turn the platter and change the rebate shape or eliminate it.
How much do you get back on your rebates?I think you mean rabbets.
John, you would not use a parting tool to take off the tenon. I suppose it could be done, but there are much better ways. A kitchen knife might make a skinny parting tool, but a little thicker steel would probably work better.Thanks again. I have seen old knives cut and ground to make a parting tool. Might try it with an old knife that isn't used in the kitchen. Should work better for "detail" use. Present PT is 1/4 inch wide.
HI, Dean. This is a 10 inch chef's knife and the back is heavier than a paring knife, filet knife or veggie knife. I'll measure but looks to be about 1/8th inch thick. The closer to the handle, the thicker the blade. Should work OK.
The difference between rebate and rabbet (not to be confused with rabbit, a cute furry animal with long soft ears) is a couple thousand miles of ocean. Over there it's a rebate while it's a rabbet over here. Regardless of how you spell it, I believe that the pronunciation is more or less the same if we try to imagine normalizing accents. Maybe it's splitting hairs (or hares), but I think that "mortise" might be a more suitable name for the recess.
This cracked me up. And I agree it should be mortise, not rebate. But for that matter jointers don't join, they plane; and planers don't plane, they thickness.
