I backed myself into a corner with my latest turning project and had no way to cut a recess for mounting on a chuck. It was between centers and the tailstock live center was in the way. I remembered an article written by Mike Peace where he made a tool for this very purpose. He was the inspiration for my tool.
I figured if I was going to the effort why not make it so I can do the dovetail for both a spigot and a recess. The photos show what I came up with. I made it from HSS 6x25x200mm. Most of the grinding was straight forward. However the one angle for the recess-cutting dovetail was less than 90 degrees and couldn't be done on my grinder. I tried a cutoff wheel in a die grinder but I just wasn't steady enough to get the results I wanted.
I'd just acquired a chainsaw sharpener and thought I might be able to adapt it to a poor mans tool grinder. Lots of ideas floated around involving machining a new base to replace the chain holder. All more time and effort than I was willing to commit. I found that by removing part of the chain holding parts I was able to hand hold the tool steel against the base and get acceptable results.
