drill press column clamp
Clancy, MT
Hello, recently went about searching for a drill press column clamp. I could only find 1 USA made clamp that unfortunately is to large to fit my 1 7/8" old Delta column! Anybody know of any other sources/manufactures? Thanks and safe chip making!
Dick, if your drill press table has slots, then F-clamps are your friend. They can hold thicker, thinner, wider, narrower. These live on my table. Have to pull the plastic cap off to get them in & out, but that is no biggy. Your slot size may vary.
Another possible solution. Works well for me and holding power is impressive.
Smallest diameter in practical use is around 4" when drilling with a 2½" forstner bit, tight but works.
