I have a old Canadian General lathe, the person that I bought it from had the 4" riser block put on and had 2 banjos one with a 4" riser and one for the full height without the extension.I use the short one without the extension on the outboard headstock end which has a shelf mounted to a carving vise which comes in very handy, the full height one is a little to tall. So my problem is the banjo that is full height has the bolt that holds the tool rest on the left side, the other one is on the right side, so I was wondering if I could drill and tap a hole on the right side? On both banjos, there is an extra bit is metal where the hole is, what are your thoughts? Thanks
