Congratulations to Craig Morton, People's Choice in the October 2025 Turning Challenge (click here for details)
Congratulations to Andy Chen for "Mesquite Vase with Polymer Clay Millefiori" being selected as Turning of the Week for November 3, 2025
I just finished rough turning a Holly end grain hollow form. I did not seal thinking it was unnecessary. I place in a cardboard box for drying. Is this the correct action? Is final turning decision based on weight and moisture just like a bowl?
Wall thickness is a big factor in drying
My process is to turn to a wall thickness of about 3/16” thickness.
After turning I put the form in a box with the flaps closed
2nd day I leave one flap closed so 1/2 the top is opened
3rd day I ope all top
4th day take it out of the boy set on a shelf. It’s ready to sand and finish.
The box provides a humidity chamber that keeps the faster drying areas of the form from drying too fast.
Thicker wall will require more drying time and perhaps a different approach
If you leave it thick enough to re turn the extra precautions are needed. I seal all end grain areas and any sharp edges. Then put in a paper sack or box with the lid closed. I probably do more than is necessary but I would rather err on side of caution
