Is anyone using Silicone Gel Beads to fast dry turning’s???
Thanks, I run a searchEldon.....you should run a search for this. I recall this being discussed at some point in the past.
My bad Dave.. thanks for the heads up.Try searching on silica (not silicone) and dessicant.
Emiliano - Is the drying solution just desiccant or is it a liquid solution? Cannot find it on the web.I used the "drying Solution" from Thomas Stegall. Works well. But, I turn way too many bowls to do it on a regular basis. I think that the weekend turner could benefit from that.
The drying solution is little beads. They change color when they need to be dry in the oven. I asked Thomas Stegall today where to go for it. He said to contact him directly. He is on Facebook. He runs the "Woodturning Connection" group. If you are not on FB, I can get his address for you. He sends you a nice booklet with instructions, no need to guess how to do it.drying green wood turned bowls in Silica Desiccant beads?
Have any of you turners every tried this. I just heard about it and wanted to get some more info on this method. Pro's and conswww.aawforum.org
