Easy Wood 4" 1.25 x 8 tpi Chuck Used Excellent $299
Charlottesville, VA
Used 4" Easy wood lathe Chuck. Very Good Shape barely used Our feature-packed 4", 4-jaw Easy Chuck™ design keeps you focused on turning instead of managing your tools. Simply use the supplied ball end hex key, depress the keeper latch, slide each jaw off, then slip any size Easy Jaws™ into place. Listen for the snap and the jaw is locked into position and ready to use in 30 seconds or less. Ten Easy Jaw options accommodate small to larger size objects and grip in either expansion or contraction mode for greater versatility.
john@stubdrums.com
