Has anyone ever used these for bowls? I plan on getting me a set for my pen turning but was wondering if they would be useful for bowls also.
Thanks!
Thanks!
And NO, I will never drive an electric car!!
I appreciate the video John. Looks pretty cool. I'm not really looking for a carbide dedicated to bowl turning. I was initially looking at them for doing acrylic pens. Was just curious if they worked on bowls also. Looks like they do. As others have mentioned, I'm already learning more about using my bowl gouges along with sharpening, which sometimes is still not that great, but I think they would be helpful if one got in a pinch and didn't want to ruin a nice piece of wood.Since you already use a spindle gouge I would suggest the Hunter Hercules or Hunter Viceroy for turning bowls. Both are excellent for this purpose when used as a scraper but they also work well as bevel rubbing tools to clean up the cuts. Here is the Hercules video
Still looking for the Viceroy video.
If you really want a set of the flat carbide tools look at the Woodpecker Ultra shear. They come sharper and the shaft is better designed to work both as a scraper, and shear scraper or a bevel rubbing tool.
they will drive themselves
Peter - did you use the grinder/jig method of sharpening before you bought the Sorby system? Your thoughts on how the Sorby system is better? ThanksI started turning before carbide was a big deal. Then it seamed like carbide was the next best thing to sliced bread.
So I bought one. Every few months I get it out and then I realize why it was in the drawer. Nothing beats a a SHARP HSS gouge.
The key is a sharp tool and sharpen often..
Once you “learn” how to sharpen it makes turning so much better, easier, fun.
Not sure who said it but once you think you should sharpen your tool it’s too late. I use the Sorby sharpening system and it is easier repeatable..
I had then Oneway Wolverine system and was quite happy with it. BUT I did not have a CBN wheel.Peter - did you use the grinder/jig method of sharpening before you bought the Sorby system? Your thoughts on how the Sorby system is better? Thanks
You know the more I've been looking at sharpening jigs and systems, I'm steering more towards this Sorby system also. It's a little high dollar but it seems to be more of a no nonsense sharpening system that would be great for beginners. I'm getting halfway decent with my sharpening but I know my tools would be much happier with better profiled edges. So are do you have a Pro & Con list you'd like to share? Thanks!I had then Oneway Wolverine system and was quite happy with it. BUT I did not have a CBN wheel.
However I moved across the country and sold a lot of my equipment. When I landed I bought the Sorby set up. Quite happy with it. I like the flat cutting surface vs. the concave. It is very easy to touch up my tools. And with the various belt grits I can achieve a
Very sharp edge.
When I went to the local club meeting last month I noticed they had the OneWay system setup there. The meeting place is one of the members personal shop. As for learning, I may make a couple mistakes but I will eventually conquer anything I buy. Lol Thanks Dean!One additional thought about sharpening systems to consider when shopping for your first: what do the people in your area/club use? If everybody in your town uses the Tormek and you buy the One Way, who's going to help you learn to use it? And get the most out of it? Glenn Lucas taught himself to sharpen on all available systems, so he could understand his student's problems and help them sharpen better (Now that's dedication), but few others have significant experience with anything but their own method.
I've seen the CBN wheels. They are pretty pricey also. Right now, as a new woodturner, I'm gonna try to figure out what the right one for me is. Right now I'm just looking at simplicity, space and accessories. I know everyone has their own methods and I'm sure some have even changed methods over the years. I predict that I will fall into that category also, but for now I will just try to find a system that will eventually lead me to taking control of my own sharpening. I appreciate all the help and comments y'all. It's nice to have a place filled with such knowledge and experience that a person can ask a question and get informative answers even if they aren't the same. LolYou can turn a bowl with a dull tool.as.long as you handle the gouge correctly. Granted it's more fun and easier with a sharp tool.
I guess Glen and I have something in common. I have a grinder with both CBN and aluminum oxide. I have a strip sander and I e been playing with different grits to learn more. I also have a Tormek so playing with that as well. For me so far the CBN is the best overall. I'm still playing.
I love the Robo Rest. I use it for many of my tools. The Oneway system with the Wolverine jig is for my other tools.
My little 6" delta actually runs pretty smooth. My older one used to vibrate all my tools off the work bench. Lol I'm running 2 Norton wheels. One is an 80 grit blue wheel and the other is a 150 grit white. I also dressed the edges to a little round.I don't think vibration has been mentioned yet, but it is very important that the grinder run essentially vibration free or else you won't be able to get a good sharp edge. Most grinders as they come out of the box need a tune up to run smoothly. The six inch grinders seem to be worse probably because of their light weight and lower cost. The main causes of vibration are:
The grinder is tuned up when you can run the grinder with a glass of wine on the tool rest. I don't know why it has to be wine, but beer, water, cheap wine in a box, or Coke Zero just won't hack it.
- Stamped bevel washers that don't run true. You can buy machined washers that do a much better job.
- Cheap plastic bushings that don't do an adequate job of centering the hole in the wheel. Metal bushings should be used.
- Cheap wheels that may not be perfectly round and/or not have centered holes. A diamond dresser usually can address this problem, but not the handheld type. It needs to be the type that is connected to the tool rest.
