Easy Wood replacement cutters
Panama City, FL USA
What is your preference for replacement cutters?
1. Use only genuine OEM from Easy Wood
2. Reputable 3rd party like Arizona Carbides- I’ve used them before and was satisfied.
3. Some of the Chinesium sub-$3 each replacement cutters on Amazon and EBay.
They will all wear eventually and need to be rotated and/or eventually touched up with a diamond plate on the flat side. I do have some negative rake cutters, but don’t see any way to refresh those when dulled, and I’ve stuck with OEM on those. They are patented but I’m sure there are knockoffs (intellectual property theft, if you will) I’m just trying to think about the sweet spot between cost and value. Thoughts and suggestions appreciated. Thx
I also buy most of my inserts from AZ Carbide. If they don't carry something I will buy OEM.
By the way, AZ is located in Michigan. I think the AZ refers to A to Z, but I could be wrong.
Personally, I'd be concerned with catastrophic failures with the Chinesium (great word) parts. Micro fissures maybe or some other quality issue that results in part of a cutter being launched off the tip.
