Congratulations to Phil Hamel winner of the April 2025 Turning Challenge (click here for details)
Congratulations to Steve Bonny for "A Book Holds What Time Lets Go" being selected as Turning of the Week for 28 April, 2025
I have a couple of extra Faceplate Rings that fit over a 50MM 2" standard set of chuck jaws w/stainless steel mounting screws. $20.00 each includes shipping Item is 3" in diameter and 3/8" thick metal contact Mikeee12345@aol.com
This would fit most adjustable chucks the inside diameter of the ring is 2.05" which fits most common 50mm chuck jaws when they are closed.
If someone has a slightly larger set of jaws I could put the ring in my metal lathe and open the inside diameter a few thousandths if needed.
These will readily fit all of the Nova series chucks with the 50mm jaws installed.
